Author Topic: most minimum epsxe cpu setup with good performance  (Read 1407 times)
starcrudph
  • Last login:April 04, 2006, 05:43:30 am
« on: November 19, 2005, 08:14:17 am »
hi. what is the lowest possible hardware i could use in a win98se mamewah/espxe cabinet. someone is selling me his computer and was wondering if this could deliver the goods already:
p3 slot 1 600-700mhz
256 p133 sdram
32mb nvidia agp
10gb maxtor hard disk
via mobo
i hope someone has had a good setup with even lower specs...that would make mine a sure bet.thanks all.
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
Re: most minimum epsxe cpu setup with good performance
« Reply #1 on: November 19, 2005, 03:42:56 pm »
256 p133 sdram
32mb nvidia agp
via mobo
Now a days these specs are called the "lowest specs" :)
btw Epsxe and Mamewah works best in Xp.
I have done a good setup with the same hardware.
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
« Reply #2 on: November 21, 2005, 06:41:35 am »
I have a more powerful PC but am having a few nagging issues running ridge racer type 4 on epsxe.
Anyone notice a bit of slowdown in that game when you use inside car view?
ahmer
  • Do as you like.
« Reply #3 on: November 22, 2005, 06:39:34 am »
Epsxe can run very fast on a powerfull Pc.
If you configured it properly i belive that it should be fine.
