Author Topic: Check out this new commercial driving "cab"  (Read 1377 times)
AC.
  • Last login:January 21, 2015, 03:55:07 pm
    • MAME console
« on: November 19, 2005, 12:31:02 am »
http://www.hotseatinc.com/
Driving framework setup. Has potential.
mhermann
  • Last login:October 04, 2019, 07:10:08 pm
  • We ain't found.........
Re: Check out this new commercial driving "cab"
« Reply #1 on: March 22, 2006, 04:58:45 pm »
So anyone using one of these? Looking into building a dedicated driving cab. This might be a nice part of that.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #2 on: March 23, 2006, 08:10:46 am »
Price For Pro Version:  From $1,299
Special order item
They look a bit expensive for a bit of welded steel tube and plastic pipe joints... It'd probably cost you no more than $200 in materials to knock one of those together yourself. It'd probably be a bit stronger if you did.
The cheaper ones are even less in materials... But if you must have one off the shelf, then I suppose they'd be OK to use.
Best Regards,
Julian (Fozzy The Bear)
« Last Edit: March 23, 2006, 08:16:46 am by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
