Author Topic: Replacing a storm door  (Read 1571 times)
« on: November 18, 2005, 04:26:37 pm »
I have a long line of home projects I've tried on my house that mostly ended up craptacular.
I need to replace a storm door.
How hard is this, really?  For some reason I fear that it will come out badly.
Stingray
Re: Replacing a storm door
« Reply #1 on: November 18, 2005, 04:49:01 pm »
This project falls under the pretty easy catagory IMO. Even I can do it. Best I recall, all I needed was my cordless drill and a couple of screwdriver bits.
-S
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
« Reply #2 on: November 18, 2005, 04:49:59 pm »
Shouldn't be bad at all, assuming you're planning on replacing it with another storm door of the same dimensions and not something like, say, an elephant...  An elephant would entail far more work, and the results are generally less than spectacular.
Hanging doors is easy...  Just be sure to double check your measurements.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
xar256
  • Last login:February 03, 2025, 08:50:13 pm
« Reply #3 on: November 18, 2005, 07:01:20 pm »
duffjr
  • Last login:January 19, 2012, 05:50:14 pm
  • There is no dinosaur name ending in PUSS.
« Reply #4 on: November 18, 2005, 08:14:18 pm »
i read this topic as replacing a sperm donor.
fredster
  • It's all good!
« Reply #5 on: November 18, 2005, 09:17:00 pm »
You might need a jig saw with a metal cutting blade.
If you have to install the frame, it's a new level of pain, but otherwise easy.
« Reply #6 on: November 18, 2005, 09:20:30 pm »
That is because you are a flaming homosexual.
danny_galaga
  • Last login:Today at 02:45:34 am
    • dans cocktail lounge
« Reply #7 on: November 18, 2005, 09:21:06 pm »
i dunno, if you have to ask...
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #8 on: November 19, 2005, 12:27:21 am »
it's a really easy task
on a scale of 1 - 10 I give it a 2
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #9 on: November 19, 2005, 09:55:38 am »
Yep, I agree...But if you neeed to chisel out the hinge part, then you're screwed.  ;D
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #10 on: November 19, 2005, 09:23:32 pm »
If you can't replace your storm door, you'd better sell off all your pins and anything that has an electrical cord, since it's only a matter of time before you shock yourself to death.
It'll take more actual TIME to do this than actual WORK, but unless you're BUILDING a new storm door (which you'd still be able to do - it's nice to make something yourself that beautifies a house from the OUTSIDE too....I've got an article if you want to give that a go), budget 2 hours for this, and when you get done early, use the extra time to congratulate yourself with several dozen downings of your favorite libation.
Reading the directions beforehand (since you've never done this before) will make the process quicker and identify any possible tools you'll need to round up before starting.
« Reply #11 on: November 19, 2005, 09:24:57 pm »
Heh... for some reason, my projects on the house never come out quite right...
missioncontrol
« Reply #12 on: November 20, 2005, 01:07:44 am »
pppffffttttt  :P flathead screwdriver and a hammer works wonders
Jabba
  • D-Hutt
« Reply #13 on: November 20, 2005, 11:52:21 am »
<- 1151....???
DrewKaree
  • HAH! Nice one!
« Reply #14 on: November 20, 2005, 02:25:19 pm »
