Author Topic: ATTN Minwah: Mamewah question  (Read 1227 times)
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
« on: November 14, 2005, 06:28:35 am »
I filtered over 2000 MAME games from my total mamewah list one by one. However I want to avoid filtering again, should I upgrade my ver of mamewah.
Minwah, where is the info for game filtering stored? I could not find a cfg or ini file anywhere.
Re: ATTN Minwah: Mamewah question
« Reply #1 on: November 14, 2005, 11:37:49 am »
Filter files use the .FTR extension, in the \files folder, however you DO NOT need to worry about these since you didn't 'filter' the list as such rather create one manually.
I think you are interested in the .LST file(s) - it should be pretty obvious which one(s) you want to keep, eg mame-1.lst etc.  If you want to upgrade Mamewah, you could always do so and then copy these .lst file(s) back into the \files folder - the LST format is still the same so you won't have to start again.
darthbane2k
« Reply #2 on: November 14, 2005, 11:43:36 am »
