Author Topic: WG K7000 Pre-cap questions  (Read 1822 times)
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
« on: November 13, 2005, 04:02:46 pm »
I've finally gotten around to getting the replacement parts for my K7000.  I stripped it down today, and when I flipped over the chassis board, I found a few extra parts from previous repairs.  I want to verify what I'm seeing with others and get any comments from the experts.
  • There is a jumper wire from the negative pole of C45 attached to a ground point.  I'm assume this is due to not being able to get a solid solder joint on that leg when the caps were replaced by the previous owner.
  • There is a capacitor attached between the negative pole of C50 and the leg of R75 that is connected to C52.  I don't know why this is there.
  • There is a 650 ohm resistor attached across R83.  I believe this is the same value as R83, so I'm wondering if the original resistor is bad (open).  I haven't had a chance to desolder anything yet to test that theory.
  • There is a 330K resistor attached across the vertical hold pot.  I assume this is just to change the resistance of the pot and put it into a range that allows the control to work properly.
A picture of the back of the board is attached.  Can anyone confirm my assumptions and also comment on the ones I wasn't sure about?  Are any of these common repairs or fixes to this chassis?  When I put the new caps in, should I just leave all of these extra pieces around?  My plan here is to swap the caps and the flyback using the kit I got from Bob Roberts.
SirPeale
  • Green Mountain Man
Re: WG K7000 Pre-cap questions
« Reply #1 on: November 13, 2005, 05:21:42 pm »
That actually may be factory work.  I've seen a lot of chassis' with similar parts on the solder side.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: November 13, 2005, 07:21:13 pm »
Yes, those were all put there at the factory. Leave those parts alone.
Captain_Dingo
« Reply #3 on: November 13, 2005, 08:13:03 pm »
Point taken :)
Thanks for the help.  The only reason I assumed it was from a prior recap is that there's some blackening on some solder joints as if someone got them too hot while working.
I'm off to heat up the iron...
