Author Topic: Where is Pos+ 5 volts on PS Game Pad?  (Read 983 times)
SomeDude
  • Last login:November 29, 2005, 05:20:37 am
« on: November 12, 2005, 01:10:40 pm »
Someone told me that in the set of wires that leads to the game pad the Red wire is the +5 volts I need to hook up the P360 made by Happ. When I checked it with my meter it was only 3.5 volts. I read somewhere else that it NEEDS to be 5 volts in order for the stick to work correctly. Anyone know where the right voltage is?
spiffyshoes
  • Last login:September 20, 2015, 01:24:46 pm
Re: Where is Pos+ 5 volts on PS Game Pad?
« Reply #1 on: November 12, 2005, 02:02:58 pm »
There is no +5v on a Playstation Pad.
SomeDude
« Reply #2 on: November 12, 2005, 02:57:41 pm »
How can I use an external power source? Dont I need to use the ground wire from the pad to the negative wire on the joystick so that the up/down/left/right to register and work right? How do I use a transformer? Should I just show the dude at radio snack what I want to do and he will know how to help me? The stick I have is about 1 year old and Ive never hooked it up. I never used a transformer before.Sorry...
« Last Edit: November 12, 2005, 03:03:54 pm by SomeDude »
