Author Topic: HELP: Reversed X-Axis on Trackball?!?  (Read 2889 times)
njchan
  • Last login:December 22, 2025, 02:38:42 pm
« on: November 12, 2005, 11:06:51 am »
I have a Happs Trackball with PS/2 interface PCB.
I've got it working in Windows for the most part ... only problem is the x-axis is reversed for some reason.  Meaning ...
when I move the ball up and down the cursor moves up and down ...
but when I move the ball left, the cursor goes right ?!?!  wtf?
and when I move the ball right, the cursor goes left ?!?!
anyone know how to fix this?  I tried reversing the connector on the trackball to PS/2 interface, but that didn't do anything.
any ideas?
Rocky
Re: HELP: Reversed X-Axis on Trackball?!?
« Reply #1 on: November 12, 2005, 10:58:54 pm »
You need to swap a couple of pins on the Happs optical board.
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #2 on: November 13, 2005, 08:13:44 am »
If you followed the instructions on the Optipac site, they're backwards.  They say where to connect the wire by colour for a happ trackball.  I followed it too and had the same results.  Just swap the x wires and the y wires.
Either that or you installed the track ball with the arrow that points to the monitor the wrong direction.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
TOK
  • The Game Always Wins
« Reply #3 on: November 16, 2005, 01:37:56 pm »
You mounted the trackball backwards. Flip it around.
seanp
  • Last login:January 05, 2015, 12:48:13 pm
  • Dreamcast / PC Mame in progress
« Reply #4 on: November 16, 2005, 06:02:51 pm »
Nope...  turning the trackball around 180degrees will result in the up/down axis getting reversed.  Somehow the lef/right leads are backwards.  I made my own mouse hack for my trackball, and did this exact thing by accident.  switch the pins for left/right, and voila it works fine.  If BOTH axis were moving the wrong way, then turning it around would fix it.
"when I move the ball up and down the cursor moves up and down ...
Clones are people, two.
TOK
« Reply #5 on: November 17, 2005, 08:27:58 pm »
I misread his post. I actually misread it on 2 counts, because when he said PS-2, I assumed it with the one with the hardwired harness.
Sorry for the confusion.
