Author Topic: where can I buy lexan ???  (Read 4588 times)
abefroman
  • Last login:May 16, 2011, 09:20:34 am
« on: January 23, 2003, 12:27:20 pm »
home depot ?  Lowes ?  where else ?
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
Re:where can I buy lexan ???
« Reply #1 on: January 23, 2003, 12:35:11 pm »
Lexan is a brand name, and home depot carries it.  I did not see any at lowes, but I bet they have something similar (different name).
eightbit
  • My cab is never done...
« Reply #2 on: January 23, 2003, 01:22:57 pm »
Any big box home improvent store or even most smaller hardware stores should sell it. Craft stores are another option.
Darkstalker
  • Last login:June 27, 2010, 12:55:36 am
  • A legend in my spare time...
« Reply #3 on: January 23, 2003, 01:49:29 pm »
I think Lucite is another name for it if you are looking at Home Depot...
Still in the collecting parts and ideas phase of cabinet building.
hyiu
    • www
« Reply #4 on: January 23, 2003, 02:46:52 pm »
where are you located ??...
In NYC, there are plastic shops also... have all sorts of lexan, plexiglass stuffs....
maybe if you let us know where you are... someone here might actually pin-point you to some shop nearby...
Silverwind
« Reply #5 on: January 23, 2003, 03:02:54 pm »
which location typically has the lowest prices on lexan? (home depot, local shop, etc??)
El Pato
  • Last login:January 31, 2003, 09:17:03 am
  • I'm NOT a llama! I'm a duck!
« Reply #6 on: January 23, 2003, 03:39:35 pm »
This is kind of off-topic, but why would a person choose Lexan over some of the other "lesser" brands (crystallite, I think is one)?
I was told that Lexan is super durable but scratches real easy.
I picked up a 32 x 44 piece of Lexan at Home Depot this weekend for around $37, but now I am second guessing using it for my control panel cover.
What type of material out there like Lexan is durable yet doesn't scratch as easily?
eightbit
« Reply #7 on: January 23, 2003, 03:52:29 pm »
Lexxan is less brittle and should scratch less than the cheaper variants of plexiglass like crystallite. Plexiglass has a tendency to shatter or crack when machining it if your not carefull.
If you have plexi that is scratched they make scratch remover for it. Its easy to find in automotive stores because its used for cleaning clear windows on convertibles. Its not going to remove deep scratches but it does a good job with scuffs from normal wear.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #8 on: January 23, 2003, 04:27:58 pm »
Lexan is a brand name that GE uses for their polycarbonate plastics.
Check this thread for more info
American Laser Games Wrapper
O2em Rom Utility
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
« Reply #9 on: January 23, 2003, 04:31:20 pm »
Plexiglas is also a brand name!
Check it out here: http://www.atofinachemicals.com/atoglas/index.cfm
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
« Reply #10 on: January 23, 2003, 04:31:28 pm »
The downside of a material that doesn't scratch as easy is that its more brittle. Normal Plexi fits into this category. Its terribly hard to drill 20+ holes into without cracking. Lexan is far easier to work with and its stronger (ie. more flexible and resists impacts better before breaking) but this also makes it softer and more prone to scratches.
In a home environment it will be fine. If not? Well its not like you haven't built it once before. Maybe in a year or two you'll have to do it again.. no biggie. Lexan is by far the better choice. More expensive? Not if it takes you 3 sheets of plexi before you don't get a crack......
« Last Edit: January 23, 2003, 05:03:39 pm by Brax »
If you build a frankenpanel, chances are I don't care for you as a person.
Silverwind
« Reply #11 on: January 23, 2003, 04:58:55 pm »
yes.. but I don't think it's quite the same..  Plexiglass with two "S"s is a the general term.. they just spelled it different to create a brand name out of it..  I could be wrong
ErikRuud
« Reply #12 on: January 24, 2003, 11:42:19 am »
Plexiglas is a brand name that gets used as a general term for polyacryl products.
Just like Kleenex is used for facial tissues.
O2em Rom Utility
Darkstalker
« Reply #13 on: January 25, 2003, 05:38:12 pm »
And Scotch Tape is also a brand...It's clear celaphone tape...Band-Aids (Adhesive bandage)
I feel like Randel in that Clerks cartoon now...heh
SNAAAKE
  • -Banned-
« Reply #14 on: January 25, 2003, 05:51:40 pm »
[which location typically has the lowest prices on lexan? (home depot, local shop, etc??)
Doesnt really matter..because most hardware like ace,home depot will have them for around the same amount..its not worth the headace of looking for the cheapest lexan because worse to worse you are gonna get a fair deal from home depot(look elsewhere and ya might save like $2 ;)).but i my answer is Ace hardware first because they might cut it to size for ya and then homedepot(cut it yourself ;)).
eightbit
« Reply #15 on: January 25, 2003, 08:14:16 pm »
My home depot has a plexi cutter, my local Ace doesn't sell plexi so YMMV.
Kilgore
  • Last login:September 27, 2021, 10:53:34 am
  • Mmmmm, Video Games...
« Reply #16 on: January 27, 2003, 05:35:18 am »
I got mine at Lowes.  I was buying a piece for my monitor glass and two pieces for my marquee.   I was looking at the different sizes and trying to figure out how big I needed to get all of my pieces.  While I was waiting for the sales person, I noticed they had a trashcan inside of the cutting area full of scraps.  When the person arrived I asked about it and he said I could have anything I wanted and they would even cut it.  So I was able to buy a smaller sheet for my monitor glass, and got my marquee pieces for free :-) YMMV
