Author Topic: Dynamo Panel - width difference  (Read 1384 times)
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
« on: November 11, 2005, 10:49:10 am »
I've got an old Dynamo cut-corner style cabinet, and bought a replacement control panel on eBay - SFII layout, guy even punched a seventh "Neo Geo" button for me no problem.
So I take it over to my cabinet, line up the hinge, and try to close the panel.... THUNK!  It hits the sides!  Damn thing looks like it's about 1/8" too wide!  I should just be able to grind it down or something, but does anyone know anything about the differences in widths in seemingly identical Dynamo cut-corner style control panels?  I thought these Dynamo cabinets were all identical.
(first image is the original panel, second is the replacement panel, please excuse the grainy cameraphone image)
Scott84
  • Last login:May 17, 2022, 08:24:59 pm
Re: Dynamo Panel - width difference
« Reply #1 on: November 11, 2005, 01:03:46 pm »
Try sanding the sides a bit. On my arcade, it would rub sometimes so i just used sanding by hand and it made a difference. Mine had some rough edges along the sides. I have a similar set up.
"Computer games don't affect kids, I mean if Pac Man
affected us as kids, we'd all be running around in
darkened rooms, munching pills and listening to
repetitive music." -- Marcus Brigstocke
thebrownshow
« Reply #2 on: November 11, 2005, 01:38:51 pm »
Yeah, I figured I'd just try and grind the panel down a bit, it's about 1/8", so it's not all that big of a deal, was just a little surprised.  Thanks for the tip!
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
« Reply #3 on: November 11, 2005, 04:55:24 pm »
The wood on your cab likely shrunk.  I bet if you measure the width between the side panels front and back, you'll find it to be about 1/8th narrower in the front.
Scott84
« Reply #4 on: November 11, 2005, 05:42:45 pm »
thebrownshow
« Reply #5 on: November 13, 2005, 09:36:00 pm »
Doesn't look like it, the new panel is actually bigger than the existing panel.  So unless the metal shrunk too...
