Author Topic: Need(ed) help installing After Dark 3.2 Screensaver under WinXP (fixed)  (Read 5210 times)
Tiger-Heli
    • Tiger-Heli
I am trying to install After Dark 3.2 (Marbles, Flying Toasters Screensaver) on a WinXP computer.
Lots of information is available here, but I thought I would get a quicker answer here and then post the results there.
Anyway, I downloaded and installed AD 3.0 from this site and it installed fine within the limitations of the program (more below), but it gave me a nag screen about ADW30.386 not being loaded and the program not activating in full screen DOS sessions.
« Last Edit: November 11, 2005, 03:19:31 pm by Tiger-Heli »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Need help installing After Dark 3.2 Screensaver under WinXP (off-topic)
« Reply #1 on: November 09, 2005, 10:35:37 am »
WOW, they still make After Dark?!
No, wait, I just checked the site where you got 3.0 from and it says made in 1994. I would guess it just won't work in XP. It was made for Win 95 after all.
NO MORE!!
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: November 09, 2005, 10:48:01 am »
You need to read through my post again.
AD 2.0 (made for Windows 3.1) works in WinXP (with some glitches).
AD 3.0 (made for Windows 3.1) works in WinXP (with some glitches).
AD 4.x (made for Windows 95) works in WinXP (with fewer glitches).
AD3.2 (made for Windows 3.1) is an upgrade to AD 3.0 and won't install in WinXP (NT/2K?), even though it installs fine in Win98 (95/ME?)
I am trying to figure out how to get 3.2 to install, and if anyone wanted to create the program from scratch that would be WinXP (and faster hardware) compatible, that would be nice also.
2600
« Reply #3 on: November 09, 2005, 12:03:20 pm »
Is there a file I could change so the upgrader program would think I am running Win98 instead of WinXP?
Right click on the exe, Properties, Compatibility.
Check run this program in compatibility .......
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: November 09, 2005, 12:07:07 pm »
Yeah, actually I did that with all of these, worked for the other ones, but not that one. . .
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: November 11, 2005, 10:06:20 am »
Found some solutions:
I downloaded the upgrade from AD 3.0 to 3.2 from the bottom of this page but when I tried to install it, I got an error that I needed to be running Windows 3.1 or Windows for Workgroups.
DeafBug
  • Last login:April 14, 2008, 06:00:35 pm
  • HUH?
Re: Need(ed) help installing After Dark 3.2 Screensaver under WinXP (fixed)
« Reply #6 on: November 12, 2005, 10:11:41 am »
Thanks for the information.  I have the After Dark saver.  I also have the Disney and Star Wars saver.   I still have the original disks.  Now I have something to do.
