Author Topic: T-Stick Plus Footrprint  (Read 1609 times)
thebrownshow
  • Last login:December 14, 2010, 03:14:32 pm
« on: November 08, 2005, 01:40:29 pm »
Anyone else have an issue with the mounting bracket on the T-Stick Plus being smaller than most normal-sized mounts?  I have a metal Dynamo control panel from a Street Fighter cabinet and it appears that I'll need to drill new holes to mount the T-Stick Pluses.
Anyone ever make an adapter plate or have any other suggestions?  The drilling just isn't a problem, just mainly curious as to why the T-Stick's plate is so different, even from the J-Stick.
PileDriver
  • Last login:May 28, 2025, 08:53:44 am
  • I want to built my own arcade!
Re: T-Stick Plus Footrprint
« Reply #1 on: November 09, 2005, 07:19:00 am »
I made a new plate for mine because I didn't want to drill any new holes in my panel. If you can just drill new holes then that's the way to go.
gravity242
  • Last login:March 08, 2025, 10:29:47 pm
    • Super Pacman Restoration
« Reply #2 on: November 14, 2005, 09:06:35 pm »
I ran into this problem myself and found a remarkably easy solution:
Basically, I bought a metal junction box cover plate from Lowe's for $.92 and made it into a replacement mounting plate for the T-Stik Plus.  The plate I bought measure 4.625" x 4.625" and had a perfect hole already cut into the center of it.  I simply had to punch out the circle from the center and drill 8 holes into it.
I used the original metal plate from the T-Stick Plus as a template to drill the first set of holes.  I lined up the center "joystick" hole with the punched-out hole of the junction box cover.  This first set of holes are the screw holes which attach the plastic base of the joystick to the plate.  I also counter sunk them to match the original.  The metal of the junction box plate is fairly soft so it's not as difficult as it might sound.
I then lined up the center hole of the junction box plate with the base of Happs Competition and drilled the mounting holes out.  You could, of course, line up the plate with the holes in a control panel and just mark them off that way.  You'll have way more flexibility with the junction box plate than the original.
If this isn't clear enough, let me know and I'll post some pics.  It's almost hard to believe how well a junction box cover works in place of the original plate.   Well, I suppose they're both just small squares of sheet metal, but still....   ;D
Too bad you can't just grab a tree by the very tiptop and bend it clear over the ground and then let her fly, because I bet you'd be amazed at all the stuff that comes flying out.  - Jack Handey
gravity242
« Reply #3 on: November 14, 2005, 09:10:37 pm »
Here's a picture of what the plate looks like.  (ignore the box it's attached to)
thebrownshow
« Reply #4 on: November 15, 2005, 09:54:09 am »
That's pretty much what I'm doing as we speak, we had some spare sheetmetal at work, so I'll be making a new plate.  I'll post pics when it's finished.
Paladin
  • Mmmm llamaburgers!
« Reply #5 on: November 16, 2005, 09:35:20 pm »
Thanks for the timely posts!  I'm just transferring control panels, and was thinking I'd have to drill extra holes.  I bought one of those same plates, and it worked like a charm.
A simple solution that made me slap my head and say "why didn't I think of that"!
