Author Topic: can i unplug my keyboard from x-arcade build your own controls set  (Read 1094 times)
grayxx
  • Last login:July 27, 2006, 07:25:32 am
im using the x-arcade build your own controls set, can i remove my keyboard so it isnt lying around on top of my cocktail cabinet, i unpluged it but the controls dont work
« Last Edit: November 07, 2005, 02:54:12 pm by grayxx »
RichyRich
  • Last login:November 17, 2006, 12:22:40 am
  • If it ain't broke don't try and fix it
Re: can i unplug my keyboard from x-arcade build your own controls set
« Reply #1 on: November 07, 2005, 03:32:30 pm »
You want the usb adaptor.No keyboard required.
grayxx
« Reply #2 on: November 07, 2005, 03:51:14 pm »
how does that work then, does the board plug into the pc via this usb adapter??
Crowley
  • Last login:January 25, 2006, 04:07:23 am
  • Wakka-wakka-wakka-wakka
« Reply #3 on: November 07, 2005, 05:52:13 pm »
Ya, for the X-Arcade Dual that I have, you need to plug a keyboard in the back, but I just took a really old one apart for the matrix and stuck it in back there.
"It's Raining Sideways!"
SQrL
  • Last login:November 24, 2014, 02:00:29 pm
  • The Game is Never Over!
« Reply #4 on: November 07, 2005, 07:37:48 pm »
I used the controler board from an X-Arcade Dual (mainly for its console compatibility) to build my Control Panel.  I use the USB adapter for it and you do not need to plug in a PS/2 keyboad into the back of X-Arcade.  In fact, I have a regular USB keyboard plugged in for typing, etc...
