Author Topic: Illustrator question  (Read 1412 times)
menace
« on: November 06, 2005, 04:02:33 pm »
So i'm just starting out in illustrator but there are some quirks with the program that are currently baffling me.  For starters--say I start a new layer--no problem--sometimes (and not always) as soon as I select my first point it fills in this "matching" feature and then the layer goes partially  transparent--I have no idea why it does it sometimes and not others and how do i unmatch them so that all layers are standalone?  I have attached a picture to show what dots I'm referring to.
 Also, are you not meant to manipulate a point until the area is enclosed?  say if I click three points then a fourth which i try to change the anchor point type, all previous points disappear and I have to scroll around with my mouse until it shows up and only then am I able to connect the fourth point back to the other 3.
mahuti
Re: Illustrator question
« Reply #1 on: November 07, 2005, 02:36:35 am »
Apparently on the dots filling in thing... you are somehow using "appearances" from the appearances pallette... which you can sometimes inadvertently begin using is you you are drawing with a "brush" selected, rather than just using the stroke pallete to set the size of your stroke. If you don't want appearances... try just opening up a new doc and making a bunch of layers, make soem objects with the pen tool... without choosing a brush. If appearance dots are showing up then... you have a problem. I don't use appearances, or any of the other fancy illustrator tools like brushes and effects and junk... if you are it may be causing you some irritation. The illustrator help docs are pretty helpful and thorough. Look in them for more info on that.
You can manipulate points as you create them. Instead of creating a point, then going to the pallette to use the "change point type" tool... you can just click-add a new point, hold and drag and it will begin its life as a curve point. The only reason the whole thing would disappear would be if you clicked off of the line at some point. It can be irritating trying to select 1 specific point after you have created an object (for instance without selecting the whole line) , but it's usually fairly simple to add points, so I'm having a bit of difficulty imagining where you are going wrong. :-/ Illustrator is a very powerful tool. It can also be a very irritating one.
menace
« Reply #2 on: November 09, 2005, 10:02:23 pm »
thanks mahuti!  As a newbie to this, sometimes even the most simple tasks can be quite frustrating if you have no idea what you are doing  :D  Now that i know how to manipulate these litttle things my project is proceeding quite well!  (super flipper pinball backglass if you were wondering)
