January 09, 2026, 02:06:14 am
Problem: (USB Only) Board appears not to work until WinIPAC is run every time. Yellow exclamation marks in Control Panel, Device Manager.This is a rare problem, and is caused by a registry error. It is suspected that this problem occurs if the board is regularly swapped from one USB port to another, or different board versions used on the same PC. The fix involves registry editing, the usual caution should be observed.Run regedit, and open Hkey_Local_Machine/System/CurrentControlSet/Enum/HID and delete the keys containing VID D209 Also Hkey_Local_Machine/System/CurrentControlSet/Enum/USB and delete the same keys. You might have to right-click and set permissions to do this. Unplug and re-connect the board.Quote
First off, Hoopz is right.
I recently had the same problem, but after moving my USB plug to the first USB input on my motherboard, it solved the problem. For some reason it did not like the second port???Thanks Hoopz for the answer to my question too.John
