Author Topic: Preventing Escape from AtomicFE  (Read 1194 times)
gonzobrian
  • Last login:April 18, 2011, 08:42:08 pm
  • This space for rent!
« on: October 27, 2005, 09:05:58 pm »
I am going to run AtomicFE as my Shell once I get everything set up like I like.  I have an admin "esc" key to exit roms.  I have notice that my 7 year old frequently hits the esc key twice and exits from the FE.  Is there a way to disable the exit from Atomic?  While Atomic is my shell there really is no need to exit.
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
Re: Preventing Escape from AtomicFE
« Reply #1 on: October 30, 2005, 03:17:48 am »
Hi Gonzobrian,
You can do 2 things.
1- you could change the exit key of Atomic to another key. (it will avoid the problem of the double typing on escape)  And if you define a key you can not access with your cab controls , the exit will be disabled.
2- You can active the password asking on Exit.
(On the "options" tab, check "Ask for password on exiting front end". then click on the Define button. (you can enter a password using only your cab controls ,ex: left left right).
If you choose this option, when you press ESC on the FE, it will prompt you a password before exit.  If you enter a wrong one or after few second if you enter nothing it will go back to the FE.
hope it helps.
gonzobrian
« Reply #2 on: October 30, 2005, 05:04:28 pm »
Hey Youki!  Thanks for the help.  I did not think about the password option.  Is there a way to change the default lenght of 6 characters?  Delete and back space don't seem to work.
youki
    • Atomic Front End
« Reply #3 on: October 31, 2005, 03:09:30 am »
No, i think i fixed the password lenght to 6 characters.  :-[
