Author Topic: Can I view what resolution is used?  (Read 1026 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: October 23, 2005, 09:52:54 pm »
OK, in MAME, if I view Game Information, I can see what the ORIGINAL game hardware used for resolution. If I hit F11 I can see framerate info. Is there ANY way, for MAME to show me what resolution it ends up actually picking for display? (Assume that MAME is using "resolution = auto" )
NO MORE!!
Tiger-Heli
    • Tiger-Heli
Re: Can I view what resolution is used?
« Reply #1 on: October 24, 2005, 06:18:38 am »
Only way I know is with your monitor's OSD, if that displays it.
« Reply #2 on: October 24, 2005, 09:40:30 am »
Turn on debug (debug 1 in mame.ini), and then check the log file after loading a game.
Remember to turn off debug when you're done so it doesn't max out the logfile size over time.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #3 on: October 24, 2005, 12:44:29 pm »
Another way is to turn verbose on: "verbose 1" in mame ini, or "-v" at commandline.  Look at the output on the commandline for the "Best mode" and "Primary surface" lines.
Robin
Knowledge is Power
