Author Topic: MAME 0.63 Game Warnings  (Read 2333 times)
toyguy
  • Last login:January 26, 2004, 11:07:11 pm
« on: January 19, 2003, 06:28:55 pm »
Can anyone point me at the location in the source to get rid of the game warnings that appear when launching a game with MAME 0.63.  If I launch Lunar Lander, for example, from the command line using MAMEPP, it displays a warning that the game may not play correctly due to a bad rom dump.  It will do this every time I launch it.  I'm bypassing the disclaimer and game info screens using the new command line switches, but I need to get rid of these warnings as it causes Emulaxian, my FE, to hang upon launching the game because the notice is hidden at that point.
I can reveal the MAME launch process with an Emulaxian option, but I don't want to do that as it ruins the whole FE effect for my cabinet by making Windows appear.  I thought I had found the spot in usrintrf.c by commenting out the DO loop in showgamewarnings() but that didn't do it.
TG
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Coming Soon
toyguy
Re:MAME 0.63 Game Warnings
« Reply #2 on: January 19, 2003, 07:27:23 pm »
This seems to be different in MAME 0.63 now.  There is no little window with a Press OK message.  Now it appears in the DOS box just after you press Enter for the command line.  Looks like this warning is coming from a different place.  That's probably why my one attempted change didn't work.
If anyone has done this for 0.63, I'd be grateful to know where.
toyguy
« Reply #3 on: January 19, 2003, 08:13:05 pm »
Never mind :^)
After a bit more reading, I see that this is really a bad rom warning, which is in common.c.  I got that taken care of, as well as the other screens.  Thanks for the tips!
TG
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
« Reply #4 on: January 19, 2003, 09:15:35 pm »
How did you fix it if you don't mind me asking.  I'm having the same problem with the US arkanoid.  I know i can just play arkanoid world, but thats beyond the point.  I'm interested to know what you did to fix it though.
-Kevin
toyguy
« Reply #5 on: January 20, 2003, 12:13:39 am »
Follow the link below and check the topic about getting rid of the OK screens.  It also describes getting rid of the Bad Rom warnings.
http://www.fraggersxtreme.com/arcadepanels/faq.htm#How%20do%20I%20get%20rid%20of%20the%20blasted%20"Click%20Ok%20to%20continue?"%20screens
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #6 on: January 20, 2003, 02:16:18 am »
0.63 allows oyu to get rid of the OK screens in the ini file/ command line options.
Homebrew
« Reply #7 on: January 20, 2003, 08:14:31 am »
Sorry about that.  I followed the link earlier but only seen how to get rid of the ok screens listed.  I didn't bother to go to where it explained that cause i already knew how to recompile without those.  Little did i realize the bad rom info was listed with getting rid of the OK screens.  Doh!
-Kevin
