Author Topic: Marquee Retainer won  (Read 3262 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: October 22, 2005, 10:29:11 am »
bought a couple of marquee retainers from fleabay. they're both identical - one for the top and one for the bottom.
problem is the bottom one won't fit on properly - it sticks out.  are there other types of marquee retainer available? or has anyone got any suggestions?
thanks
here's a pic:-
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
Re: Marquee Retainer won
« Reply #1 on: October 22, 2005, 10:48:25 am »
The framing used for drop ceilings should work for you, or any other L shaped item.
As far as specifically labeled "marquee retainer" stuff, I think it all has that bulge.
Cutty
  • Last login:July 23, 2009, 10:48:30 pm
  • Cabin Cruiser
« Reply #2 on: October 22, 2005, 11:49:29 am »
Yeah your speaker board should be recessed, you could probably find like a black L-bracket if you want it flush, but that wouldn't look as sharp
