Author Topic: Converting a Street Fighter Arcade to Ninja Turtles  (Read 2437 times)
shmoo422
  • Last login:November 27, 2005, 07:35:47 pm
« on: October 20, 2005, 08:33:40 pm »
I have a street fighter II arcade currently, but I just bought a turtles board to switch it out just for a change. I just swapped the boards out and it works fine, except I can only get one player (both coin slots count towards player one). Would I have to re-wire the jamma harness to get two players?
  • Last login:June 25, 2025, 03:09:16 pm
Re: Converting a Street Fighter Arcade to Ninja Turtles
« Reply #1 on: October 20, 2005, 11:28:26 pm »
I could be wrong about this, but the problem could be that street fighter did not make a difference as to which slot the coin was placed in, you could put your coin in slot one or two, and it could be used for either player, and TMNT cabinet was deticated coin slots and players (if you put the coin in slot one, you could only be player one - Leo and you could only play leo on joystick one; and then slot 2 =player 2 which is mike on joystick 2...same for coin slot three and four respectively)
your cabinet may just have wired both coin slots as just one switch...but thats just my guess. I think it should be not toohard of a fix.
shmoo422
« Reply #2 on: October 21, 2005, 12:22:38 am »
yea I think that might be true. Setting it to free play should solve the problem huh? Cept I can't get it to work, these are the switches:
DIP SWITCH NO. 1 SETTINGS
1. COIN SWITCH NO. 1 SETTINGS
SW     1      2      3      4     COIN   PLAY
O     OFF    OFF    OFF    OFF   1      1
       ON     OFF    OFF    OFF   1      2
       OFF    ON     OFF    OFF   1      3
       ON     ON     OFF    OFF   1      4
       OFF    OFF    ON     OFF   1      5
       ON     OFF    ON     OFF   1      6
       OFF    ON     ON     OFF   1      7
       ON     ON     ON     OFF   2      1
       OFF    OFF    OFF    ON    2      3
       ON     OFF    OFF    ON    2      5
       OFF    ON     OFF    ON    3      1
       ON     ON     OFF    ON    3      2
       OFF    OFF    ON     ON    3      4
       ON     OFF    ON     ON    4      1
       OFF    ON     ON     ON    4      3
       ON     ON     ON     ON    Free Play
1. COIN SWITCH NO. 2 SETTINGS
SW     5      6      7      8     COIN   PLAY
       ON     OFF    OFF    OFF   1      2
       OFF    ON     OFF    OFF   1      3
       ON     ON     OFF    OFF   1      4
       OFF    OFF    ON     OFF   1      5
       ON     OFF    ON     OFF   1      6
       OFF    ON     ON     OFF   1      7
       ON     ON     ON     OFF   2      1
       OFF    OFF    OFF    ON    2      3
       ON     OFF    OFF    ON    2      5
       OFF    ON     OFF    ON    3      1
       ON     ON     OFF    ON    3      2
       OFF    OFF    ON     ON    3      4
       ON     OFF    ON     ON    4      1
       OFF    ON     ON     ON    4      3
       ON     ON     ON     ON    Void
When I turn the first 4 switches on and keep the 5-8 off, nothing happens. It still says "insert coin", does anyone have this board? I would imagine it should say "free play" or something on the bottom when its turned on.
SirPeale
  • Green Mountain Man
« Reply #3 on: October 21, 2005, 04:24:19 am »
Why would you turn 5-8 off?  It seems to me by that chart you displayed you'd have them all on, to 'void'.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: October 21, 2005, 12:33:03 pm »
try 1,2,3,4,5,6,7,8 all ON
NO MORE!!
shmoo422
« Reply #5 on: October 21, 2005, 02:00:03 pm »
yea i tried turning them all on as well.......that makes it 4 quarters for one play. Could my switch be messed up?
RayB
  • There's my post
    • RayB.com
« Reply #6 on: October 21, 2005, 02:03:55 pm »
Could be.  Did you try test mode? Some test modes display the dipswitch settings.
By the way, you are talking about the Turtles board or SF2? If Turtles, did you buy a 2-player Turtles board or the 4 player one?
NO MORE!!
shmoo422
« Reply #7 on: October 21, 2005, 06:14:03 pm »
yea I will try test mode in a sec. I have the four player version, I'm just trying to get two players to work though
shmoo422
« Reply #8 on: October 21, 2005, 06:21:53 pm »
test mode just told me "Mask ROM okay", so that didnt really help me heh
RayB
  • There's my post
    • RayB.com
« Reply #9 on: October 22, 2005, 11:33:44 am »
OK and you can't tep through to the other test? (usually you can, by pressing a certain button. it takes you to other tests)
Also where did you get the dipwitch diagram? Are you sure you got the one for the 4-player board?
NO MORE!!
shmoo422
« Reply #10 on: October 23, 2005, 08:20:24 pm »
the guy I bought it from said he doesn't think turtles has a free play mode. Can anyone confirm that?
