Author Topic: grr anybody have the special bit for nintendo guns  (Read 2175 times)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« on: October 16, 2005, 08:46:22 pm »
just as the sub says i need the special bit that will take out the screws. it has a round head but there are cuts in the head where the bit is supposed to go. kinda like a reverse star bit. anybody know where i can get one
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
Re: grr anybody have the special bit for nintendo guns
« Reply #1 on: October 16, 2005, 09:25:27 pm »
Take a bic pen, remove the ink tube. Using the plastic tube heat it with a lighter untill its mushy. Jam the mushy plastic into the hole over the screw, allow to harden, you now have a new bit :)
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
« Reply #2 on: October 17, 2005, 01:21:42 am »
yea, I would just drill those out or use a screw extractor.
-Ace-
I want my own arcade controls!
dema
  • Last login:September 02, 2014, 03:05:34 am
« Reply #3 on: October 17, 2005, 01:36:09 am »
look on ebay or lik-sang.com might have it
meanbean
  • Last login:March 29, 2007, 11:17:06 pm
  • Needs to stop playing Ikaruga.
    • Meanbean's Yellow Fog Light Conversion
« Reply #4 on: October 21, 2005, 08:34:25 am »
Sounds like you need a gamebit screwdriver.
Lean, Mean, Driving Machine.
How-To on Yellow Fog Light Conversion
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #5 on: October 21, 2005, 11:07:35 am »
I could use one of those too for future use.
Is that the right one?  They don't provide a pic of the actual head.
tray262
  • Last login:February 13, 2022, 07:07:52 pm
« Reply #6 on: October 21, 2005, 11:09:39 am »
I look for a security bit kit. I get them at the local flea market. It's normally a 30 piece set or so. Has some very weird bits. but they work great. I wouldn't buy the gamebit, If I remember correctly the gamebit that they sell is mostly for the gamecube and it's going to be too big. I think you're better off with this http://cgi.ebay.com/33pc-SECURITY-BIT-SET-torx-hex-star-bit-screwdriver-237_W0QQitemZ6006828693QQcategoryZ50383QQrdZ1QQcmdZViewItem
Good luck!
Tray
Crazy Cooter
« Reply #7 on: October 21, 2005, 11:41:49 am »
I don't think that has the right bit.  It's kind of a "cog" shape.  Almost a reverse torx bit... almost, but with flat spots like a gear.
Franco
« Reply #8 on: October 21, 2005, 11:57:01 am »
Seriously, if you want to do it now use this method. Thats what I did to remove the security screws on my n64.
Crazy Cooter
« Reply #9 on: October 21, 2005, 12:34:10 pm »
I don't know if that would work.  There is a nut on the back of the bolt that is set in the plastic tight enough that the plastic holds it.  Any rust involved would probably snap the plastic bit.  It's worth a try though.  Especially on mine since it's rust-free  ;).
I tried taking a pic of the bolt head... then touched it up  ;).
meanbean
« Reply #10 on: October 21, 2005, 02:10:47 pm »
Crazy Cooter, that is exactly what a gamebit screw driver looks like.  I've seen people use other materials besides remolded plastic to get these screws out so do whatever it takes but remember there is aways an easier way.  Good luck to you.
Crazy Cooter
« Reply #11 on: October 21, 2005, 02:17:30 pm »
Cool, I wasn't sure because the pic on lik-sang didn't show it.
meanbean
« Reply #12 on: October 21, 2005, 02:24:06 pm »
Np...Lik-Sang is not the only place to get it but they have reliable service and reasonable prices. If you're in the States then you can pick one up from NSC for a little less.
  • Last login:Today at 12:22:24 pm
« Reply #13 on: October 22, 2005, 01:29:16 am »
I'm just curious, is this a standard nes light gun? I have about five nes light guns (both the gray and the orange) and they all just have standard screws in them. If yours has security screws, it might be cheaper to buy an old one from ebay or a second hand store that has standard screws...
Crazy Cooter
« Reply #14 on: October 22, 2005, 12:12:04 pm »
Mine is 100% original.  I got it from the guy that bought the vs machine new.  I don't need to take it apart yet, but I figured I could get a pic of what is needed for the original poster.  If you have regular screws, I'd say your guns have all been tuned up at some point.
The only problem I've had is that I have to let the monitor warm up for about 3-5 minutes for the shots to register accurately.
SeanCyrusTowel
  • Last login:January 09, 2011, 08:42:33 pm
  • 42
« Reply #15 on: October 22, 2005, 04:32:35 pm »
ah... I get it I was thinking the same thing as Vigo, you are talking about a Nintendo Vs gun, we were thinking a Nintendo NES gun, which has the standard phillips-head screws. Guess this is our fault since it is an arcade fourm, and not the consoles section.
Crazy Cooter
« Reply #16 on: October 22, 2005, 07:05:29 pm »
What the??
How did Vigo's post get there?  It wasn't there when I posted last time... plus his timestamp is later than my response...
That's odd...
Anyhow, I should have posted that it was the arcade version.  I didn't even think about the NES gun.  My craptacular picture doesn't help either  ;).
