Author Topic: wierd issue with component and power on  (Read 1380 times)
Abomination
  • Last login:December 07, 2023, 11:18:15 am
« on: October 11, 2005, 06:32:34 pm »
Ok, I have a radeon 9600 card with a dvi-i - component adapter then that component going to my JVC 27" TV.  Works fine.  Here is the issue when I turn off and restart the compuer the screen turns blue (its the screen you see instead of static on some TV's)  And wont go back to the windows xp desktop untill I unplug the components from the video card and replug them in.  The screen then appears instantly?!?!
I replaced the cables and tried a different video card and all the same thing, any ideas?
nullb0y
  • Slow In Fast Out
    • WAT Racing
Re: wierd issue with component and power on
« Reply #1 on: October 12, 2005, 01:06:05 pm »
thats cause it isnt autodetecting it when ur pc boots your probably gonna have to unplug and replug the cable eachtime something to do with a ground not hitting properly or something
Slow In Fast Out
Abomination
« Reply #2 on: October 12, 2005, 09:47:40 pm »
well moving the cabinet, removing the back panel and unplugging/replugging each time I reboot doesnt sound to appealing to be honest with you
Harry Potter
  • Smite-bait
  • Last login:May 27, 2024, 03:33:28 am
  • Sober until banned. Can post but still can't read.
« Reply #3 on: October 13, 2005, 03:13:19 pm »
Have you checked to make sure it's not a setting on the TV?
Also make sure you have the DVI port selected as the primary. I believe the dvi ports on Radeons are secondary by default.
Now in a tasty new flavour.
Abomination
« Reply #4 on: October 13, 2005, 08:54:24 pm »
yeah I have it as primary, and i'm not sure what setting it would be on the tv... hmm
