March 09, 2026, 11:50:27 am
I've written for some AS/400 magazines in the past.Go here for many excellent mailing lists.
Thanks Guys, its actually OS/400. Sorry for not being clear on this point. It is very different from other operating systems in that you use a menu'ing system to navigate the O/S. I am used to Unix command line interfaces (hell, I still use a DOS command prompt and *blush* DOS EDIT to work on the parsers here at work. Old habits die hard). But I bet I can open and edit a file quicker than any windows guys using a mouse
Until you run into a guy using a port of VI, in which case he has edited his stuff, gone for lunch, come back and edited more stuff in the time it took you to open and close 3 files.
