Author Topic: Advice Wanted  (Read 2307 times)
BenDalton
  • Last login:May 29, 2012, 09:28:07 am
  • KingsQuest was the sh*t. I miss old-school Sierra
Advice Wanted
« on: October 04, 2005, 05:44:11 pm »
I have a 800mhz p3 w/ 192mb of ram on 98se... this is running with a Trident Blade t64 video card and an arcade monitor at 15hz.
What is the best setup for MAME (and potentially other emulators) with a front end.
I LOVE Mamewah, but wonder if I can get it to run at the correct frequency and if it can interface with advancemame. Are there any guides out there on how to get windows to boot into mamewah directly??
I tried arcadeOS through dos and it is just *ok*
I haven't tried AdvanceMenu
Any suggestions??
Re: Advice Wanted
« Reply #1 on: October 04, 2005, 06:01:07 pm »
I would first try (win commandline) MAME in Windows and (dos) MAME in dos...see which performs best and let that choose for you.
I *think* you should be able to get Windows/MAMEWAH wo run at 15khz using PowerStrip...maybe someone else can confirm that.
If you go for DOS you could give GameLauncher a try.
Tiger-Heli
    • Tiger-Heli
Re: Advice Wanted
« Reply #2 on: October 05, 2005, 07:07:15 am »
Also, try using an older build like 0.61 or .063 rather than 0.100 as your primary build and only use later builds for games that weren't available in the earlier builds.
jopenner
Re: Advice Wanted
« Reply #3 on: October 10, 2005, 10:53:39 pm »
I am running Mame 32 .087 on Win XP, P3 500 with 512 MB RAM and a FX5200 128 MB video card and life is good.
John
sportswizdan
  • Last login:April 05, 2012, 02:13:39 am
Re: Advice Wanted
« Reply #4 on: October 11, 2005, 01:03:37 am »
John...Could you please load up NBA Jam and tell me if there is any stuttering or any frames per second loss at all with your setup? I have a Pentium 3 1 gig but only 256 ram and a 64mb video card with XP...But I have skiped frames and stuttering with it...I'm missing about 20 FPS. Thanks, Dan
Fuzzguitar
  • Last login:November 26, 2012, 12:15:34 am
Re: Advice Wanted
« Reply #5 on: October 11, 2005, 08:51:29 am »
Maybe 800MHZ isn't enough for NBA JAM, my Celeron 800MHZ with 256MB used to get about 6fps on that game.
"My cab is nearly finished, no really I swear!"
Re: Advice Wanted
« Reply #6 on: October 11, 2005, 09:36:12 am »
You probably need at least 1ghz for that, probably more like 1.2ghz.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Advice Wanted
« Reply #7 on: October 11, 2005, 09:49:47 am »
I can confirm that 1 ghz is just not enough horsepower for NBA JAM.
NO MORE!!
jopenner
Re: Advice Wanted
« Reply #8 on: October 13, 2005, 09:26:50 pm »
I loaded NBA Jam 3.01 and it crawled along, stuttered, spit and farted the whole way.
I have been using this system for my older arcade games as I am a bit older and recall the games of the late 70's and early eighties.  All of these games work fine with this system.
I should look at upgrading my CPU and MB.
Hope this helps.
John
