Author Topic: Some roms roll using arcade vga  (Read 1099 times)
neil324
  • Last login:October 07, 2013, 03:53:50 am
« on: October 03, 2005, 02:54:45 pm »
hi im using an arcade vga and some times when the roms are booted they roll, this can be stopped by adjust the v-sync on the the monitor but then when you go back to atomicfe that then rolls so you have change the v-sync back ???. Also anybody know a good program to sort out roms, the ones that use a spinner or a trackball.
thanks
Pandemonium
  • Last login:December 22, 2006, 11:08:05 pm
Re: Some roms roll using arcade vga
« Reply #1 on: October 04, 2005, 12:46:26 pm »
 Hi, There are currently two utilities which can be used to generate INI files for MAME which tell the program which resolution to run every game.
MameWah Resolution Tool Can be downloaded here http://mamewah.mameworld.net/downloads/mame_res_tool.zip
Or Gavin Bensons Utility here. http://www.ultimarc.com/avres.zip
Both these utilities will scan the game list and generate INI files which specify the best resolution for each game. After running once, you don't need to worry about choosing the resolutions again. MAME will always run every game at the optimum resolution.
neil324
« Reply #2 on: October 05, 2005, 01:52:18 pm »
still getting problems, used avers but no luck, when i boot the pc its out oif sync on the motherboard bois but then alright when windows kicks in, if i change the sync then the bios is ok but windows then is out of sync ::)
neil324
« Reply #3 on: October 05, 2005, 04:55:40 pm »
think im getting somewhere ive lowered the screen res in windows down to about 320x256 and the same with the options in atomic fe and it seems to have worked better all roms ive tried work without roll except 1 ;D
