Author Topic: Monitor help needed! (with pics)  (Read 2174 times)
NeoMVS
  • Last login:October 07, 2005, 08:30:51 pm
« on: October 02, 2005, 11:17:44 pm »
Just picked up a cab used and am not that familiar with arcade monitors.
Ken Layton
  • Guru
  • Technician
Re: Monitor help needed! (with pics)
« Reply #1 on: October 03, 2005, 01:39:12 am »
That green circuit board was made by Smart Industries, a manufacturer of crane (redemption) games. It must be a ticket dispenser interface board.
Perhaps you have a medium resolution monitor being fed a standard res signal. You haven't mentioned the make & model of the monitor nor posted pictures of the cabinet.
menace
« Reply #2 on: October 03, 2005, 03:04:15 pm »
I had the same looking problem and that is in fact what the problem was--for what its worth...
NeoMVS
« Reply #3 on: October 06, 2005, 05:23:57 pm »
Not sure on the make of the cab, is a Korean candy.  Monitor is manufactured by Orion, can't find any specs on the chasis or monitor itself.  If it is a medium res monitor, is there any way I can use a standard video signal on it?  Some sort of converter perhaps?
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: October 06, 2005, 06:29:24 pm »
Is the picture rolling?
NeoMVS
« Reply #5 on: October 06, 2005, 08:54:14 pm »
The picture is not rolling.
If this monitor does happen to be a dual monitor (standard and med) where would I look to change it back to standard?  A connector somewhere on the chasis?
censei
  • Last login:November 05, 2009, 11:02:35 pm
« Reply #6 on: October 07, 2005, 01:18:37 am »
There should be a connector on the chassis usually for 15k and 24k. Don't confuse this connector with the one coming from the yoke to chassis. If there isn't a connector it probably uses another method of switching frequencies or could be automatic. Be best if you could list your monitor type also.
NeoMVS
« Reply #7 on: October 07, 2005, 08:11:15 pm »
Chasis says Orion KMP 29GGFM
Monitor is a 29"
« Last Edit: October 07, 2005, 08:17:38 pm by NeoMVS »
