Bump.
Here is the pricing info gotten from them...
GLS_2001 for Xbox - US$180 per unit
Time Master for Xbox - US$70
PC2JAMMA board - US$19
RGB to Video - US$35
PC2Jamma does no VGA video conversion, so it works similar to the Ultimarc J-Pac unit - you must use an arcadeVGA or the typical DOS/ArcadeOs setup to convert the video signal and THEN turn on your monitor. Personally I'd go w/ the Ultimarc stuff simply because of the support that you'd get.
The diff between the 2 Xbox converters is that the time master runs in Time Mode only. IOW, you set it to 99 minutes and it runs for 99 minutes. At least that is what I gather from reading the info on their site. I could be mistaken. THe GLS operates on time mode and a more regular setup.
Looks like the Ultimarc Xbox interface is probably the better bet.
Still, good to know that there are alternatives...
Brain21
