Author Topic: winxp in a cabinet- is it good?  (Read 1249 times)
starcrudph
  • Last login:April 04, 2006, 05:43:30 am
« on: September 30, 2005, 09:14:46 am »
hi. i hear that winxp isnt good for cabinet since shutting it down improperly causes problems in the long run...has there been anyone successful in tweaking xp such that shutting it down doesnt cause any long term/short term damage to the cabinet's perfomance?
2600
Re: winxp in a cabinet- is it good?
« Reply #1 on: September 30, 2005, 09:23:43 am »
Is there a reason you have to shut it down improperly?
« Reply #2 on: September 30, 2005, 09:32:59 am »
Either use a FE to shut the PC down properly, or have the power switch set up to shut down, and have the power switch easily accessible (but out of view).  I use an arcade button on the top of the cab.
XP is good for a cabinet, IMO.
loadman
    • MaLa
« Reply #3 on: September 30, 2005, 07:03:56 pm »
many FE's do this
XP Rocks. You change settings so you barely know XP is there too (if you want)
