Author Topic: Driving Games Setup  (Read 9320 times)
Driving Games Setup
« on: January 14, 2003, 08:55:02 am »
I should soon be aquiring the turbo button equipped high/low shifter.  From the diagram on Happs site, it looks as tho it operates (ignoring the turbo button) using one microswitch - ie on in low gear / off in high gear (or vice versa).
I am just thinking how this will work with various driving games.  I think it will work perfectly with the default config for the Chase HQ series, which use a 'hold button to stay in low gear, and release for high gear' approach.  But for other games eg Outrun which use a button for 'shift to low' and a button for 'shift to high' this will not work.
Is there a way in the tab menu (or ini files) to set Outrun style games up like Chase HQ?  I can't think how to do it  :-[
Failing that I may be able to add another microswitch to the controller I guess...
Thanks a lot
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re:Driving Games Setup
« Reply #1 on: January 14, 2003, 10:28:10 pm »
Thanks a lot
There is no way to change those games, besides editing the source and recompiling.
IIRC, just remove the toggle flag from the button declaration in the game's driver input section.  Others here, however, have done this and know exactly what to do.
Robin
Knowledge is Power
  • Last login:Yesterday at 07:46:44 pm
« Reply #2 on: January 15, 2003, 11:38:30 am »
Well there is another way..... wire the same input to both ends of the shifter....  Since it can only be in high or low at one time it doesn't matter if it toggles, as long as you put it in low before you start the game.
Lame I know, but it would save you some source code altering if your not comfortable with that.
« Reply #3 on: January 17, 2003, 06:21:19 am »
Thanks guys :)
I don't mind too much altering the source since I make my own build anyway, although I admit the less changes I have to make the better.
I *think* the shifter only has 1 microswitch, so I would have to mod it somehow to have a switch for low, and a separate one for high.  I'll know if this is possible or not tonight when I pick the thing up :)
Chris
    • Chris's MAME Cabinet
« Reply #4 on: January 17, 2003, 05:43:34 pm »
Not true.  The Normally Closed contact of your microswitch is, in effect, a second microswitch.
« Last Edit: January 17, 2003, 05:43:59 pm by Chris »
--Chris
« Reply #5 on: January 20, 2003, 06:21:46 am »
You're right, thanks a lot!  I hadn't thought of that for some reason :)
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« Reply #6 on: January 29, 2003, 02:07:46 pm »
The easiest way I have found is a microswitch that triggers when in high and another when in low. Assign each microswitch a keypress and you are done. Super simple and no source code changes. No hastles. Maybe overkill according to some.
A  second microswitch will cost you $2 or $3 and can be bought at radioshack. All games will be compatible.
I have a 4 on the floor in my cabinet and a microswitch is triggered when it is put in each gear. The cool thing is you can go from 1st to 4th...but nobody playing the game knows that.
1st and second gear is equal to high and low gears for games that dont use a 4 speed.
« Reply #7 on: January 30, 2003, 07:10:20 am »
How do you get it to work with games that need you to press (tap) the same key for low AND high gears (eg Pole Position)?  You'd have to wire/map two of the microswitches to the same key as Howard said I guess (?)
Chris
« Reply #8 on: January 30, 2003, 09:35:57 am »
No, they can be the different keys, just map both keys to the shifter function within MAME.
--Chris
--Chris
« Reply #9 on: January 30, 2003, 09:50:52 am »
--Chris
Great thanks!  I hadn't even tried that  :)
