Author Topic: My Cab (85% Complete)  (Read 2744 times)
rbarr110
  • Last login:October 24, 2025, 06:55:10 pm
  • I already built my own arcade controls!
« on: September 27, 2005, 10:38:47 pm »
Here is my cab, not very original....the CP is a Knieval Rip Off, the cab itself is my own design but was derived from 3 different cabs (Lusid, Knieval, and another I can't remember right now).  Still need to add a platform for the monitor, install my spinner, paint, and t-mold.
Here are a few pics
**Edit** Added a few earlier pics in the construction process a few posts down.
« Last Edit: November 28, 2005, 06:12:41 pm by rbarr110 »
rbarr110
Re: My Cab (85% Complete)
« Reply #1 on: September 27, 2005, 10:39:14 pm »
More pics
babydickonboard
  • Last login:May 22, 2008, 08:28:56 pm
  • {/....KILL YOUR TELIVISION....\}
« Reply #2 on: September 28, 2005, 12:30:34 am »
looking real nice!  do you have a name for it yet?  that was the hardest desicion on my cab.....and i still havn't made it yet.  what kindof colors are you going to use?
« Last Edit: September 28, 2005, 12:32:44 am by babydickonboard »
rbarr110
« Reply #3 on: September 28, 2005, 12:37:47 am »
Honestly don't know if I am going to name it.  Nothing I think of sounds good to me.
Once this is all done I am going to build a new CP, this one has a few screwups.  The bottom box for the CP is about 3/8" too narrow and interferes with Player 1 Joystick wiring, had to nibble away some of the MDF so the CP would sit center on the box.  Also the CP top rounded corners are too rounded and you can see about 1/2" of the box below ( I could router the corners of the box to fix that).  Also had an error in mounting the joysticks (slightly too big of a hole made), hence the bolts visible on the top of the CP which also resulted in a 1/2" long hairline crack in the plexi one of the bolt holes.
« Last Edit: November 28, 2005, 06:11:49 pm by rbarr110 »
lebanull
  • Last login:April 17, 2017, 10:55:32 am
« Reply #4 on: September 28, 2005, 10:43:35 am »
Call it "Lunatic"
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« Reply #5 on: September 28, 2005, 12:40:32 pm »
Any trouble reaching the coin door with it so far back?
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
rbarr110
« Reply #6 on: September 28, 2005, 02:03:35 pm »
Yeah - the coin door is a bit far back.  It is functional, but it's really there more for looks, I have it wired so that with a flip of a switch I can use the black buttons next to the Player 1 and 2 buttons to be coin 1 and coin 2 buttons.
rbarr110
« Reply #7 on: November 21, 2005, 10:40:57 pm »
Update with a few pics.  Used vinyl fabric to cover the cab (more info on that here: http://forum.arcadecontrols.com/index.php?topic=43807.0 )
Franco
« Reply #8 on: November 22, 2005, 07:30:50 am »
Very cool cab!
I see we have the same taste in CP graphics!
