Author Topic: Help! My Nanao is busted!  (Read 1261 times)
TravistyOJ
  • Last login:September 19, 2020, 09:34:19 pm
  • DRK LFG!
« on: September 25, 2005, 07:01:17 pm »
For some reason now my monitor only displays one line, I looked around and i guess this is a sympton of vertical deflection failure.  Is it more like that this is a loose connection somehwere or a short somehwere?  If I have to replace caps or anything like that, I think I am pretty much screwed, as I have no experience with monitor repair, and to be honest the very idea scares me.
How much do you think it would cost to have a technician fix it, or is this something that I could fix? Thanks
Anyone in the atlanta area willing to make a deal on this or help me out?  I am looking to buy or trade this cabinet anyway, so if you are in the atlanta area, it is a blitz 99 2 player cab with a switchable res nanao 26" monitor.
"It is a mistake to think you can solve any major problems just with potatoes."
-Douglas Adams
SirPeale
  • Green Mountain Man
Re: Help! My Nanao is busted!
« Reply #1 on: September 25, 2005, 07:23:52 pm »
For someone that has experience with electronics, it would be fairly easy.
If you've never touched a soldering iron, you can either practice until you can solder, or find a tech in your area.
It's *really* not that hard.  But you MUST practice first.
It is likely either a bad cap, or a cold/broken joint.  Randy Fromm doesn't have a flowchart for this particular monitor, so I can't tell you which cap(s) it would be.  But you could always just touch up the solder on all of them.
TravistyOJ
  • DRK LFG!
« Reply #2 on: September 25, 2005, 07:48:56 pm »
I mean I know how to solder and have worked with electronics before, just never monitors.
I sent an email to jomac (from what I hear he is the Nanao expert), hopefullly I will hear back from him.
But i mean is this most likely a loose connection, a short somewhere, a bad cap, or are all these problems equally probable?
-Douglas Adams
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: September 26, 2005, 12:03:55 am »
If you want to drag it up to chattanooga, I'll be happy to work on it.
Later,
dabone
Jomac
  • Last login:October 16, 2024, 03:11:19 pm
  • CapKit vs Shotgun = same result !
    • Jomac
« Reply #4 on: September 26, 2005, 01:09:36 am »
Hi Travis ,
This link pretty much covers all your questions http://www.startechjournal.com/discus/messages/3768/3151.html?1089221377
 There is an actual full pictured article in startech as well covering this very problem ,but I think you have to be a subscriber to view it .
Regards
Jomac
