Author Topic: lightguns akimbo  (Read 949 times)
G1LGAMESH
  • Newbie
  • Last login:September 23, 2005, 02:33:02 pm
lightguns akimbo
« on: September 23, 2005, 02:33:02 pm »
i have two act labs lightguns for the pc (both purchased seperately). is it possible to use the two together?? if so how? and most importantly how would you hook both of them up to the monitor at once? would you hook up one into the other and then into the monitor?? how??
MKChamp
  • Last login:February 07, 2024, 02:45:53 pm
  • Stil around.
Re: lightguns akimbo
« Reply #1 on: September 23, 2005, 04:01:13 pm »
To hook up, daisy chain the 2 together.
Plug monitor into first box, that box into box 2, box 2 into pc.
Software - if you are running xp, go get
http://urebelscum.speedhost.com/dl/analogplus83.2.7z.exe
which is analog+ version 0.83.2
Make the analog ini file look like this:
### Input device options ###
mouse                   0
joystick                0
lightgun                1
dual_lightgun           0
offscreen_reload        0
steadykey               0
keyboard_leds           0
led_mode                ps/2
a2d_deadzone            0.300000
# ctrlr                 <NULL> (not set)
paddle_device           keyboard
adstick_device          keyboard
pedal_device            keyboard
dial_device             keyboard
trackball_device        keyboard
lightgun_device         lightgun
digital                 none
### Analog+ options ###
multiplemice            1
switchablemice          1
switchmiceaxes          0
splitmouseaxes          0
resetmouseaxes          0
lightgun2a              0
lightgun2b              0
williams49way           0
That's how I got 2 act-labs running together on my xp sp2 machine.
