Author Topic: require info for WG9200 to setup advcfg -advmamec  (Read 1515 times)
Dariusz
  • Last login:November 23, 2018, 02:41:36 pm
« on: January 11, 2003, 03:39:15 pm »
Hi,
I;m setting up advmame on a WG 9200 monitor (digital, 27" with VGA input).
I need spec's for the monitor to configure the:
PCLOCK
HCLOCK and
VCLOCK
The information is used to setup advmame using the manual configuration using the advcfg - advmamec command.
The only information I have is the:
HCLOCK = 15.75-31.5 kHz
VCLOCK = 45-90 Hz
BTW,
If anyone has setup their WG9200 monitor using the advcfg -advmamec command, I would be intrested from knowing what you configuration is.
Kind Regards
Dariusz
