Author Topic: Q's Regarding DC Arcade Stick modification  (Read 3673 times)
Codger
  • Last login:May 19, 2003, 10:12:33 pm
« on: January 10, 2003, 05:57:32 pm »
I've been thinking about buying a spare DC Sega Arcade Stick and hacking it to work on my PC. However I would like to add an extra button to it for Neo Geo games.
1. What type of button does the arcade stick use? Obviously microswitched, but what size is it? And where can I buy an EXACT duplicate of the same colour? Bear in mind that the DC stick uses slightly raised convex buttons.
2. Can I cut the metal top of the DC Stick using a standard hole saw bit?
SNAAAKE
  • -Banned-
Re:Q's Regarding DC Arcade Stick modification
« Reply #1 on: January 10, 2003, 06:29:38 pm »
how about building a brand new one from scratch?
It will be easier then what you are trying to do now.
You can easyly take out the guts from the stick(so you wont have to hack another dreamcast pad i assume) you have  and use one of these converter( http://levelsix.com/products/pc/PCMagicBox.shtml)to hook your dreamcast pad to your pc...not bad idea afterall ehh :) ;)?
« Last Edit: January 10, 2003, 06:34:06 pm by SNAAAKE »
MKL
  • Last login:January 10, 2003, 06:24:51 pm
« Reply #2 on: January 10, 2003, 06:33:45 pm »
They're the same buttons that are mounted on Naomi cabinets. You can get them from arcade vendors/distributors that carry Sega parts. Check www.seuservice.com
However, your idea seems hardly feasible to me, take a look at the inside of a DC stick:
Codger
« Reply #3 on: January 10, 2003, 06:35:11 pm »
Yeah I 've seen that convertor before and it doesn't work with the arcade stick.
I would like to build a new one from scratch, but I've seen how hard and expensive it can be to make it look nice (I don't like those box shaped ones people do and marble contact paper? Gah, no thanks)
I'm thinking this would be easier and cheaper to do. I imagine the metal won't be very thick...
So any information that can help me?
SNAAAKE
  • -Banned-
« Reply #4 on: January 10, 2003, 06:41:47 pm »
the reason i gave you the idea of building a new one because i already know its not possible to add more buttons.
There isnt enough space in there to add more buttons..i used to have one of these sega sticks long time ago(when it came out) and i wasnt happy with it(the joystick looks and feel horrible,my opinion of couse).
that metal casing is not even that thick and you could easyly drill but THINK...no space for more buttons.sorry :-\
Codger
« Reply #5 on: January 10, 2003, 06:49:06 pm »
Coudn't I add a horizontal button near the A button to make a row of 4? Or would it not fit beneath the case?
eightbit
  • My cab is never done...
« Reply #6 on: January 11, 2003, 10:25:31 am »
In that pic it sure looks like you could add a one to the bottom row of 3 and make it look like it belonged.
Don't mind Snake, he posts his opinion as fact. Often he's more negative than helpfull. A couple of months ago people were laughing at 1-Up and the rotating control panel idea. Well it works now. Just because it would be hard to do doesn't mean it can't be done.
Codger
« Reply #7 on: January 11, 2003, 10:29:54 am »
Thanks for the encouragement.
But I still need to know the exact type of buttons the DC stick uses. Are they standard pushbuttons I can get from Happs? Someone help.
eightbit
« Reply #8 on: January 11, 2003, 10:53:40 am »
If you can't find the exact button you could replace  all of them.
Codger
« Reply #9 on: January 11, 2003, 11:36:31 am »
Yeah but the stick is green and I dunno where to get different coloured balls.   ;)
eightbit
« Reply #10 on: January 12, 2003, 01:27:14 pm »
They don't have to match, they could contrast. Or my favorite do every button in a different color.
SNAAAKE
  • -Banned-
« Reply #11 on: January 12, 2003, 05:29:12 pm »
YES...i know you are on a rampage of proving me wrong but...
IT IS THE FACT ! ;).
Did you ever buy one of this DC arcade stick yourself?
NO ! right?
There isnt enogh space to add...how i know?
Because I do ;D.
i am serious...there isnt enough space to add 1 1/8 buttons...
Also,i dont recall people making fun of 1up's rotating panel..its just... people thought i was little too complicated for most of us thats all(i mean you know...).
As for you,I dont think you can buy these buttons from happs..AND i also dont think they are the *original* buttons used on original sega naomi machines(like zombie revenge).
If you somehow(i dont know how) manage to drill one 1 1/8 hole on that stick(i dont think you can,i had one of these long time ago and as far as i remember) then the closest you can get is thishttp://www.happcontrols.com/wp/item_search.html?item-no=58-9613-L button.
The comp convex button from happs.get the green one because thats the only look very similer to the one on your dc joystick(its almost same).
BLEEEEEP !...wrong :P
You cant use the nut from happs button on those existing holes on that DC stick.
« Last Edit: January 12, 2003, 05:48:07 pm by SNAAAKE »
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
« Reply #12 on: January 12, 2003, 06:55:13 pm »
I think there is a converter on Happs for about $90 I saw once. After you wire all your buttons you plug it into this and it has the capability to work on arcade cabs I am pretty sure but also PC. Don't ask me if it works through USB, joystick port, or PS/2 cause I don't know I only glanced at the thing. Thanx.
-See Ya!!!
