Author Topic: Pac-Man Monitor Help Needed ^^^^^^^  (Read 1141 times)
koolmoecraig
    • My Intervention
« on: September 17, 2005, 09:40:26 pm »
I have a pac-man with a freshly re-capped Electrohome G07.
Picture looks great. The only problem is I can't get the display to move to the left a little bit.(which would be vertical) I tried the jumpers to no avail.
There is no adjustment for "vertical position". What am I to do?
Re: Pac-Man Monitor Help Needed ^^^^^^^
« Reply #1 on: September 17, 2005, 10:18:30 pm »
try standing to the right....   ;D
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« Reply #2 on: September 18, 2005, 01:12:04 pm »
My WG4616 has all kinds of adjustments.  I can't imagine yours does not have a vertical position adjustment.  You have the real deal and not mame, correct?  If mame you could adjust the position through other methods.  Otherwise try the monitor manual:
http://www.arcadehelp.com/manual/monitor/electrohome/
SirPeale
  • Green Mountain Man
« Reply #3 on: September 18, 2005, 05:26:51 pm »
Actually, I believe that's a horizontal position issue.  Try adjusting the H Sync.
Heck, fiddle with all those adjustments.  Not like you can't move them back if they don't work.
