Author Topic: MAME 0.100 IS OUT!!  (Read 3804 times)
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
MAME 0.100 IS OUT!!
« on: September 14, 2005, 03:24:23 pm »
... it's 0.100 !
That
« Last Edit: September 14, 2005, 03:27:28 pm by PedroSilva »
PedroSilva
  • Grettings !
Re: For those betting on the numbering ...
« Reply #1 on: September 14, 2005, 04:56:44 pm »
There's no gamelist on the docs folder on this version
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: September 14, 2005, 06:04:47 pm »
mame -gamelist unless they took that out.
PedroSilva
  • Grettings !
« Reply #3 on: September 14, 2005, 06:11:51 pm »
That doesn't work ...
PedroSilva
  • Grettings !
« Reply #4 on: September 14, 2005, 06:24:19 pm »
Yap ... it was removed ...
GGKoul
  • Cheesecake Apprentice
MAME 0.100 IS OUT!!
« Reply #5 on: September 14, 2005, 10:51:20 pm »
« Reply #6 on: September 15, 2005, 04:45:14 am »
Does anybody know how to get it from the executable?
Surprisingly they have not removed -listfull, so you could use this to get a gameslist...
PedroSilva
  • Grettings !
« Reply #7 on: September 15, 2005, 06:16:54 am »
What I wanted was the status of the Roms regarding sound, video and working plus name and internal name.
-listfull only gives the name.
I've checked the XML option and all the data is there. What should I use to create an excel from that? Anybody knows the best way to do it?
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
« Reply #8 on: September 15, 2005, 12:51:04 pm »
Which version of Excel are you using?
PedroSilva
  • Grettings !
« Reply #9 on: September 15, 2005, 01:22:33 pm »
chris2922
  • Last login:March 26, 2023, 01:09:41 pm
  • Silverline Jamma Cab
Re: MAME 0.100 IS OUT!!
« Reply #10 on: September 15, 2005, 01:48:38 pm »
Has the DOS command line version been abandonned by mame.net?
SirPoonga
  • Puck'em Up
« Reply #11 on: September 15, 2005, 02:34:31 pm »
Why do you ask that?  Because hte DOS version isn't currently available?  If so that's because someone else ports the code to dos so oyu have to wait.
chris2922
« Reply #12 on: September 15, 2005, 02:36:39 pm »
Right, i understand, thanks SirPoonga.
Matthew Fisher
  • Last login:April 08, 2018, 10:51:11 am
    • Matt's homepage
« Reply #13 on: September 15, 2005, 04:06:05 pm »
It took 13 days to get the DOS version of .99 after the source came out.  I, for one, will be waiting with joystick in hand (get your minds out of the gutter, you sickos!  >:() for dosmame .100 so that I can finally play Top Gunner on my Vectormame...
chris2922
« Reply #14 on: September 15, 2005, 04:48:41 pm »
So are there many of you lot still using DOS as your OS?
When i didn't see it listed i presumed we were a dying breed...
Matthew Fisher
    • Matt's homepage
« Reply #15 on: September 15, 2005, 07:31:12 pm »
I'm using it because the Zektor Vector Generator is currently supported only in DOS, and my setup is a vectormame.  Dmame now has ZVG support built in, so I can update along with everybody else.  Of course, I can still only play about 35 games...  Even if I were running standard mame, I think I would still use DOS, because now I'm confortable with it and I think its faster.  Getting that PCI soundcard working was no fun, though.
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #16 on: September 15, 2005, 07:51:05 pm »
I gave up on the Dos a while ago.
I found that Hardware manufactures Dos drivers are quire poor in general. They just don't care anymore.
« Last Edit: September 15, 2005, 07:54:57 pm by loadman »
« Reply #17 on: September 16, 2005, 07:50:57 am »
Sounds great, I didn't know stardard dmame had Zektor support.
Do you have any pics of your vector machine?  Haven't seen many before...
Matthew Fisher
    • Matt's homepage
« Reply #18 on: September 16, 2005, 09:36:57 am »
Sure.  The site blows (as does the control panel), but here it is:
http://hometown.aol.com/matthewdfisher/Vector.html
(Man, I really need to update that site!)
ZVG support was built in starting in .96, I think.  That means that, through the magic of the ZVG, we can now play QB-3 and (soon) Exidy Top Gunner (not the Taito raster game) as they were meant to be played.
« Reply #19 on: September 16, 2005, 10:50:40 am »
Cool :)  I actually have seen that one before, I remember the 'vector victor' title!
Matthew Fisher
    • Matt's homepage
« Reply #20 on: September 16, 2005, 11:17:22 am »
Thanks.  The lame pictures do not do it justice.  There really is nothing like a vector monitor, IMO.  Since these pix, I have learned how to use the tweak software that comes with the ZVG.  Basically, the display is now MUCH brighter and more intense (in the picture it looks dimmer than Tempest, which it was).  The monitor has also been recapped, which made a big difference.
Hutt
  • Last login:December 31, 2022, 11:02:48 am
  • I like eggs.
« Reply #21 on: September 16, 2005, 08:12:44 pm »
For all of you usenet users....there is a .100 flood going on right now in a.b.mame
