Author Topic: gdm-20d11 woes  (Read 2357 times)
gmillerd
  • Last login:January 15, 2003, 11:27:58 pm
  • Zap
gdm-20d11 woes
« on: January 09, 2003, 01:57:52 am »
i have a sgi indy with a wonderful sgi monitor (sony gdm20d11). unfortunately xmame isnt going to work on my indy, i am told, although it would be nice to have it as a dedicated digdug machine.
i would like to salvage the monitor however. does anyone have a recomendation for a graphics card that will support my monitor? i have a sun2vga converter/adapter. i gather the sync on green issue might be a problem still.
which i gather is this:
  Res.    1280x1024     1152x900     1280x1024     1152x900
    Hor.    81.1 kHz      71.8 kHz     71.7 kHz      61.8 kHz
    Vert.     76 Hz         77 Hz        67 Hz         66 Hz
thanks very much
BobA
  • What Me Worry?
Re:gdm-20d11 woes
« Reply #1 on: January 09, 2003, 02:29:21 am »
Here is a link with some info on running the unit on a PC.  They mention quite a few video cards but of course the company sells their own card as a solution as well. They are pushing their card over the high end cards of the other manufacturers.
http://www.mirage-mmc.com/direct/US/itm00045.htm
I run a Sun 17 inch multisync with only required a small change to combine the H and V sync of the PC to get a composite sync.
Good Luck
BobA
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:gdm-20d11 woes
« Reply #2 on: January 09, 2003, 02:39:00 am »
According to this change log xmame has been tested and runs on SGI indy.
http://x.mame.net/changes-unix.html
gmillerd
  • Zap
Re:gdm-20d11 woes
« Reply #3 on: January 10, 2003, 04:30:21 am »
thanks everyone ... guess getting a dedicated card might be the answer.
well i have irix v5.3, no IDO for making my own, and only 32mb ram (which will probably work since i have 32mb ram to run mame on a win98 celeron just fine)
if i recall the compilation notes stated v6.x was needed which makes sense.
