Author Topic: K7000 repair advice needed  (Read 1915 times)
menace
« on: September 07, 2005, 07:04:29 am »
So I'm going through the inventory and plugged in a k7000 (which I thought was working) and I get this.  This is a stable image but repeated 3 times with this weird intermittent lines--I wasn't sure how to describe it to even google an answer so I thought I would post here and see if anyone else had this isssue.
cw
  • Last login:May 03, 2025, 09:26:58 pm
  • Game over man game over
    • The Cab
Re: K7000 repair advice needed
« Reply #1 on: September 07, 2005, 09:41:44 am »
kind of looks like you pushing the wrong res into it
menace
« Reply #2 on: September 07, 2005, 10:20:19 am »
nope standard 15khz right off a game board--but i was thinking its a sync issue--i tried differnt combos of sync but they all result in the same picture so i'm thinking its a component failure of some kind
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 07, 2005, 11:14:10 am »
Looks more like you have a medium res monitor being fed a standard res signal (or vise versa).
Did this monitor have a fresh capkit installed?
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« Reply #4 on: September 07, 2005, 12:25:30 pm »
the description of your problem is not very clear.. and the picture is even worst!  :(
where do you see the bad lines?
menace
« Reply #5 on: September 07, 2005, 04:21:41 pm »
no cap kit but it is a plain jane k7000 and konami time pilot board--so no res issues there.  the picture is as you see it--the blue splotches in the upper right are supposed to read free play and as you can see this is repeated 3 times on the monitor in a static non rolling image.  As you can plainly see the problem is not easily described.
SirPeale
  • Green Mountain Man
« Reply #6 on: September 09, 2005, 07:29:11 pm »
It does look like a sync issue.  Have you tried adjusting it out?
I recently had a U5000 that gave me a similar picture (four pictures on one tube).  Turns out it was just WAY out of sync.
menace
« Reply #7 on: September 16, 2005, 07:31:14 am »
Ok you were all right and I was hopelessly mislead :D  I now belive that the monitor came out of the narc machine I once owned (how sad is that that I can't remember what games have gone through here) At any rate, I'm going to test it out on a guys med res board and see how it looks.  Thanks for not flaming me  ;)
