Author Topic: What Boot Skin Utility to Use?  (Read 1780 times)
jopenner
« on: September 06, 2005, 11:22:01 pm »
Hi,
Well here I am wading into the cabinet building arena for the first time.  I have chosen to get MAME32 running on my WinXP machine before embarking on the the actual construction.
I have got MAME32 up and running and I have my front end booting from the Startup line.  Now I need some help picking a boot screen utility.  I tried BootXP and LoginBootUI with no luck.  I have downloaded screens, but they don't seem to work.  The program seems to be looking for an executable file.  The instruction included with both programs aren't really clear on what is required.
Can someone help by steering me to a tutorial or something.  I would like a Tron theme if possible.
Thanks in advance for your advice and time.
John
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
Re: What Boot Skin Utility to Use?
« Reply #1 on: September 07, 2005, 12:11:17 am »
Try Bootskin.
« Last Edit: September 07, 2005, 07:05:48 am by loadman »
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #2 on: September 09, 2005, 02:35:10 pm »
I used a little program called BootXP (v2.5). Its not freeware but there are "ways" of making it so. Check google.
Signature tags are dumb.
jopenner
« Reply #3 on: September 10, 2005, 11:31:02 pm »
Thanks for the help folks.  It seems that Boot Skin is the go to program for me.
Thanks again.
John
sportswizdan
  • Last login:April 05, 2012, 02:13:39 am
« Reply #4 on: September 11, 2005, 11:29:26 pm »
Just curious as to what your using as your front end in Mame32?
jopenner
« Reply #5 on: September 12, 2005, 10:45:01 pm »
sportswizdan,
I am using 3DArcade/Emulaxian because it was the only front end I could get to work with Mame32.  :-\
I like it, but I am having a terrible time trying to get the skins to work properly.
I really like the classic arcade skin, but I can't get the game loading screen to fit properly. ???
What do you use?
John
loadman
    • MaLa
« Reply #6 on: September 12, 2005, 11:09:07 pm »
 :P
FYI Mame Launcher (MaLa) also works with Mame32
