Author Topic: removed  (Read 6160 times)
MonitorGuru
removed
« on: September 01, 2005, 08:28:36 pm »
removed
« Last Edit: October 05, 2005, 09:47:52 am by MonitorGuru »
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
Re: Mame .99 List of Resolutions @ Frequency (For AdvMame setup)
« Reply #1 on: September 30, 2005, 11:09:53 pm »
Since you know everything, I have a question.   ;D  How can I make sure each game is running at its optimal refresh rate / modeline stats?  For instance Pac-man.  Before it was running it at 57 Hz or something like that.  I think because I only gave it the option of 50-60 and it wanted 60.60606.  So now, based on the stats given in my monitor manual, I increased the available refresh range to 50-65.  But now it says it is using 65!  And the movement still looks stuttery like it is not in the perfect mode.  Also Pac-mania is still slow and says it is running at 65Hz also.  Very frustrating.
Vertical 224x288x60.60Hz will be what I am primarily in, since that covers most of the Pac-mans and Galaga.  So if I have to set some default, it would be that.  Just figured it could pick the best one per game but...  I also read you have to "choose between" 224 and 240 vertical lines based on what games you play, and someone with a WG D9200 was able to choose some setting in between and a range to be optimized for both... kinda lost on that one.
Lastly, I manually copied the modeline stats from advmame.rc to advmenu.rc.  Still does the same thing, telling me I have no valid modes available.   :P
TurboC--
« Reply #2 on: October 02, 2005, 01:37:41 pm »
I just don't understand why people have to create manual modelines, when the frequency info is listed right in MAME.
« Last Edit: October 02, 2005, 01:41:10 pm by TurboC-- »
wpcmame
  • Last login:February 18, 2024, 01:27:00 pm
« Reply #3 on: October 02, 2005, 01:54:34 pm »
