Author Topic: Wells-Gardner D9200 V.S. Betson (not sure which model)  (Read 3762 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: August 31, 2005, 02:54:55 pm »
time is almost upon me to buy monitor for my cab.
i read both retroblast for both monitor but here on fourm i heard different.
so how good is Betson? do they still have problem today?
what problem do each of monitor have?
thanks.......................
My website: www.bossyman15.com Lots of arcade pictures inside!
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: Wells-Gardner D9200 V.S. Betson (not sure which model)
« Reply #1 on: August 31, 2005, 04:29:51 pm »
I have the betson & i love it the picture is great & it supports 800x600 well gard does not thats a huge difference, i have spoke to kevin also he much prefers the betson
thanks
gary
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
bossyman15
« Reply #2 on: August 31, 2005, 06:35:55 pm »
but i read some of the thread here saying that some game may be off by like 5 degree and the routine (sp?) option doesn't work. is that such a big deal?
edit: also how is the text on windows and mamewah? could you easily read the texts? i also read that it was burly on some people's cab.
« Last Edit: August 31, 2005, 06:39:30 pm by bossyman15 »
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #3 on: August 31, 2005, 07:01:24 pm »
I have a betson 27".  The text is quite clear in the center but gets worse at the edges.  This is for small text like what is below a windows shortcut.  Arcade games look fantastic on the monitor though.  I also tried some genesis emulated games and they looked good too.
Everything looks great but I can notice the quality at the edges is a little degraded.  It is hard to tell when you are playing, even if you look for it, though.
I have not noticed any rotation problems on mine, but let me double check on that.
divemaster127
« Reply #4 on: August 31, 2005, 07:20:20 pm »
the text is clear on a arcade monitor, but its expected to be blurry to a point, the betson is for games not windows, also i have no rotation problems at all, if your concerned about blurry text its best to stay with a computer monitor.
thanks
divemaster
bossyman15
« Reply #5 on: August 31, 2005, 08:13:48 pm »
well i know i can't do computer monitor because i want 27" screen. but the text i'm talking about like in mamewah list of games.
Bones
  • [Moderator]
« Reply #6 on: August 31, 2005, 09:33:53 pm »
This is totally incorrect. D9200 most definitely supports 800x600 resolutions with no problems.
divemaster127
« Reply #7 on: September 01, 2005, 10:54:05 am »
This is totally wrong, i sell both of the betson & wells garder, the d9200 only officially supports 640 x 480, if you run it above that you are voiding your warranty...the happ techs have told me if you run it at 800 x600 the life will be much shorter
thanks
divemaster
divemaster127
« Reply #8 on: September 01, 2005, 10:55:38 am »
Also if you read the review of the D9200 at retroblast.com it states the same thing
thanks
divemaster
whammoed
  • Last login:February 17, 2026, 12:42:21 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #9 on: September 01, 2005, 11:04:13 am »
thanks
divemaster
Thats not what the Wells Gardner techs say though.  They say the current d9200 will do 800*600 fine, they just haven't updated their specs.
divemaster127
« Reply #10 on: September 01, 2005, 11:11:42 am »
Below is a quote take from kevins site at retroblast.com
"PC Monitor Performance
The D9200 does a good imitation of a PC monitor, even though its roots are firmly planted on the arcade-side of the display equation. It is a multisync-capable monitor, or it can be set to run exclusively as a CGA or EGA monitor. (Since it is a PC monitor, it's even compatible with the ACT Labs light gun!)
As a PC monitor, the picture quality is very good at 640x480. It's every bit as sharp and vibrant as a regular PC monitor (only at 27" the picture is huge!). At 800x600 the image is not as sharp, but considering it's not an officially supported resolution, that's to be expected."
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #11 on: September 01, 2005, 11:19:46 am »
And Kevin's review was on a much older revision of the monitor than is produced now.
The current ones support 800x600 at 60hz just fine. The originals only did 800x600 at 56hz.
Kevin's review is over 2 years old now.
Call wg's tech support and ask them the monitors specs.
9500 West 55th Street
whammoed
    • NiceMite
« Reply #12 on: September 01, 2005, 11:24:45 am »
I love Kevins site as much as anybody but its far from an official source for Wells Gardner information.
diabolic
  • Last login:August 26, 2007, 02:36:22 pm
« Reply #13 on: September 01, 2005, 12:03:57 pm »
I have only had my 9200 for about a month, but it works fine at 800x600@60hz for windows and the front ends I run using the ArcadeVGA.  I did run the TRISYNC utility for the ArcadeVGA and that cleaned up the 640x480 and 800x600 modes.  Not as crisp as a computer monitor, but the text isn't hard to read.  Definitely good enough to use as the front end in my cabinet also.  WG says the 800x600@60hz mode works fine on the new 9200s and doesn't shorten the life.
bossyman15
« Reply #14 on: September 01, 2005, 01:49:44 pm »
mmmm maybe i will go with betson...
model#44-4070-RT is that right?
Effayy
  • Last login:August 18, 2006, 02:09:07 pm
  • Slowest....Cab Builder.... EVER.
« Reply #15 on: September 01, 2005, 08:03:59 pm »
May I just ask what revision of the monitor supports 800x600 at 60hz?
I have a revision D... Just making sure for myself, here.... :)
- FA
diabolic
« Reply #16 on: September 01, 2005, 11:22:44 pm »
Mine says "Rev: D" on it.
Silverwind
« Reply #17 on: September 08, 2005, 07:07:45 pm »
That is the version I have..  44-4070-RT.    It was $399 + tax when I bought it.
bossyman15
« Reply #18 on: September 08, 2005, 07:18:20 pm »
all right, ok
Silverwind
« Reply #19 on: September 08, 2005, 07:29:16 pm »
all right, ok
I can post some pictures of it later tonight..
l3ft3r1s
  • Newbie
  • Last login:September 15, 2005, 02:59:35 am
« Reply #20 on: September 11, 2005, 12:05:44 pm »
Hey, a newbie here needs some help!
Is there anyone from Europe who managed to get that Betson 44-4070-RT / Kortek KT-2914 screen?
If yes, where did you got it from? Is Kortek cheaper? Does Kortek ship from Europe or only from Korea?
Thank you :)
bossyman15
« Reply #21 on: September 12, 2005, 01:44:50 pm »
grrrrr
today was to be my road trip to betson store in SF. but i called first and they said they don't have them in stock(44-4070-RT)! they said they would get more of them last friday but no they still don't have them! >:(
also they said the price is $469.95, rats! i was hoping it would be around say... 399
