Author Topic: zsnesw and fceu, no video  (Read 1863 times)
BlackFox
  • Last login:March 24, 2010, 11:30:16 am
  • Joystick Junkie
« on: August 29, 2005, 04:13:52 pm »
this is a weird one, my mamewah is finnaly up and running and all my emulators and roms are working except snes and nes. whenever i go to select a game, the music plays for the game, so i know its being loded and the game is being run, however the emulator isnt displaying any video at all.
i was having the same problem with mame a little while ago, figured out i needed to turn off d3d and a few other gizmo's, however in snesw's cfg file, theres only a few video options and fceu is a little bit beyond complicated.
ive pulled a rom and the emulator to my main rig and they worked fine, im not quite sure what exactly the problem is here.
the specs on my arcade machine is a p4 1.8, 128 of pc133 (which im thinking could be my problem), wd 40gig, and a geforce4 mx440 running svid out.
« Last Edit: August 30, 2005, 04:43:27 am by BlackFox »
"Your Anger Is A Gift" - Zack De La Rocha
BlackFox
  • Joystick Junkie
Re: zsnesw and fceu, no video
« Reply #1 on: August 30, 2005, 04:43:50 am »
nobody?
2600
« Reply #2 on: August 30, 2005, 08:11:02 am »
Change your video resolution in zsnes and fceu.
« Reply #3 on: August 30, 2005, 08:19:22 am »
Set {safelaunch} in your commandline for those emulators (in mamewah).
BlackFox
  • Joystick Junkie
« Reply #4 on: August 30, 2005, 03:03:03 pm »
i lowered the resolutions in both, it fixed fceu but zsnes is still being gay. and the safelaunch tag was already set. i already updated zsnes, i just dont know why its doing this.
2600
« Reply #5 on: August 30, 2005, 03:11:40 pm »
What resolution are you using?
What resolution are you using for fceu?
What video settings are you using?
Information is helpful.
BlackFox
  • Joystick Junkie
« Reply #6 on: August 30, 2005, 09:33:16 pm »
well mamewah is set to 800X600x16 along with my desktop
for fceu im using 320x240
and for zsnes ive been trying to find a good resolution to run it at, but right now its running at 800x600 win r
interpolation is off, newgfx engine is off (which i dont know what that is, maybe someone knows?) and vsync is off
vsync is also off in fceu.
im running all this into a 27" tv
« Reply #7 on: August 31, 2005, 05:24:51 am »
Make sure your emulators run OK from a commandline.
Then check and triple check you are using {safelaunch} - it sounds like exactly the problem you get when this isn't set.
Oh, and you're running ZSNES in a Windowed mode, change it to some fullscreen mode.
BlackFox
  • Joystick Junkie
« Reply #8 on: September 01, 2005, 04:26:03 pm »
well i goto run zsnesw.exe from a command line and it does nothing
the safe launch tag is up, and its on all of the other emulators as well
and i changed to 800x600 dr full, i only switched to the windowed mode to see if it would work. it was just what it was on at the moment, ive tried almost every resolution i can.
« Reply #9 on: September 01, 2005, 06:21:03 pm »
What commandline are you using (what are you typing)?
