Author Topic: Mame Function Buttons  (Read 5839 times)
mpm32
  • Cheesecake Master
  • Last login:November 20, 2018, 09:25:14 pm
« on: January 06, 2003, 11:44:21 am »
I am planning my control panel for my cab and I have been looking at many examples.  I have noticed that most have a row of "function" buttons across the top; esc, tab, ~, etc.
If an IPAC is used can't these functions be accessed using the shift function?  Is it necessary to put these extra buttons on when using an IPAC?  Anyone using an IPAC with no additional function buttons along the top care to share their views/experience?
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
Re:Mame Function Buttons
« Reply #1 on: January 06, 2003, 11:59:07 am »
I've found the shift functions work great.
But, I am adding 2 small atari cone buttons for "coin" and "escape" so I don't have to explain the shift-versions to everyone who visits.
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #2 on: January 06, 2003, 12:07:49 pm »
I have a small set of buttons like youre describing. Since I'm not using all 8 buttons of both players that the Ipac provides for, I went with the 'alt' setting. This way I could map p1 buttons 1-5 normally, than use 6-8 and all the p2 buttons(I only have a 1P side right now) for esc, f2,f3,tab, and whatever else is needed
eightbit
  • My cab is never done...
« Reply #3 on: January 06, 2003, 01:09:56 pm »
I'm using an Ipac and don't have any extra buttons for administration. My coin slots are wired and working but I also have coin buttons hidden under the front overhang.
I also have a trackball with mouse buttons wired so thats what people use to select games and they use the shift method to Escape. Explaining one shifted key isn't to confusing for most people.
Smittydc
  • because its fun!
« Reply #4 on: January 06, 2003, 01:25:00 pm »
I wired my trackball mouse buttons to two of my player-1 buttons.  Nothing wrong with having them serve different in-game and out-of-game purposes.
mpm32
  • Cheesecake Master
« Reply #5 on: January 06, 2003, 01:57:42 pm »
I wondered about this.  What if for example I wired the trackball/mouse left click button to button one of the IPAC for the fire button.  Would pressing the fire button also the left click button repeatedly cause any problems i.e. exiting the game and such?
« Last Edit: January 06, 2003, 01:58:11 pm by mpm32 »
Smittydc
  • because its fun!
« Reply #6 on: January 06, 2003, 02:45:53 pm »
That's exactly what I did -- the fire button is wired to both the sw1 input on the IPAC and the left mouse button on my Opti-pac.  Hasn't caused any problems -- and it's fun surfing the net with my trackball.
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
« Reply #7 on: January 06, 2003, 04:09:28 pm »
I am a fan of the classics, so I did not set up my CP for four players or six buttons per player.
I used the extra I-Pac inputs for a row of buttons at the top.  most of these buttons are set up to serve a dual purpose using the shift function. I did not want to have to explain (or remember) what that shift player1 button 1 was the tab key.
Across the top I have Pause, Advance, Coin 1/shift, Start 1, Start 2, Coin 2,On Screen Display(~),Config(tab),Enter
The shifted functions are Escape, Reset, shift, Start 1, Start 2, Coin 3, Save, Load, Enter.
Escape and Reset are shifted so that they cannot be hit accidently.
American Laser Games Wrapper
O2em Rom Utility
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #8 on: January 07, 2003, 01:15:11 pm »
If you're using MAME, the "shift" function is built in. My newest control panel is a USB gamepad hack and has no additional function buttons across the top.
Bob
lordsub
  • Last login:March 24, 2003, 02:36:52 am
  • I want a wabinet!
« Reply #9 on: January 07, 2003, 11:28:43 pm »
I had a question concerning this two.  On games like X-Men, TMNT, Simpsons, etc...  The 4 coin slots seem to matter, because you get to play the character depending on which slot u put the coin...So does that mean you need 4 coin buttons as well as 4 player start buttons?  if so, i can see a shift key being handy here.
hyiu
    • www
« Reply #10 on: January 08, 2003, 12:20:18 am »
actually, if you want, you can assign the same key as coin and start....
so, when you press, you insert coin and start at the same time.... it will work for most games....
somehow, some old games will not work.... needs separate coin button.... donno why...
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #11 on: January 08, 2003, 12:48:43 am »
Don't even need an ipac to do the shift stuff if you use just mame.
Look at my cab, all I have is Quit(Esc), power, and Pause.  They will be labelled at some time. That way when friends come over they don't ask how to quit or pause, there is a single button to do that.
gajaman
  • Last login:July 19, 2011, 02:50:33 pm
  • The GajaCab is here......
    • The Gaja Project
« Reply #12 on: January 08, 2003, 03:47:52 am »
I didn't want a load on admin buttons either so I wired a shift button and put it between the speakers below the marquee (it's a black button on a black panel so blends in nicely).
Theres a pic on my site of the speaker panel if it helps in the cab section. www.firenza.pwp.blueyonder.co.uk/arcade
