Author Topic: DOSCab Request  (Read 4942 times)
knuttz
  • Last login:January 08, 2025, 05:36:02 pm
DOSCab Request
« on: August 28, 2005, 03:36:01 pm »
First off thank you Chris,  DOSCab is an awesome program.  I am trying to set up a skin with two long lists of songs.  I plan to run DOSCab on my real jukebox which does not have page flip buttons so I need to set up a skin with about 100 songs per strip.  When I try to do this I get the error:
"Fatal Error   SongsPerStrip invalid  (min=1, max=50)"
After I press OK on the error box the program works fine.
Would you please raise the SongsPerStrip maximum to 100 if it's not too much trouble.  This would greatly help my project.
Thanks again
Matthew
"Look at all those hamburgers. You can't eat all those hamburgers you stupid fella, OH GEEZ!" "OH he's gonna do it! He's so rediculous."
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: DOSCab Request
« Reply #1 on: August 29, 2005, 03:19:05 pm »
--Chris
knuttz
Re: DOSCab Request
« Reply #2 on: August 29, 2005, 06:50:23 pm »
My jukebox is a NSM Prestige.  It has 10 rows and 8 columns of strips with each strip containing two songs.  The songs range from 100-179 and 200-279 for a total of 160 songs.  The songs are numbered as follows:
100    110   etc.
200    210
101    111
201    211
102    112
202    212
etc.
If I set SongsPerStrip to single or double with 10 rows and 8 columns I only get two didget selection which is a problem since my jukebox is set up for three didget selection.  I also have the following options in the skin:
SelectionMethod=Numeric
UseZero=true
HighNumber=9
If I set a skin up with 1 row and 2 columns, 80 songs per strip, and the above options I get the numbering system I need (column 1 starts with 100 and goes to 179 and column 2 starts with 200 and goes to 279) but I get that pesky error that I mentioned in my first post.  I would like to set this up the correct way but I can't seem to figure it out.  Any help would be greatly appreciated.
Chris
  • Moderator
Re: DOSCab Request
« Reply #3 on: August 29, 2005, 07:04:30 pm »
--Chris
