Author Topic: MonitorGuru: low ESR cap question ...  (Read 1117 times)
JoeB
  • Last login:December 04, 2025, 08:49:00 am
  • NES Fanatic
« on: August 26, 2005, 08:25:48 pm »
My old "monitor" has a vertical deflection problem.  I've noticed one of the caps leaked. (the problem was the top 1/2 stretched, while the bottom shrunk.. until the tube got warm.. but stayed almost the same).
According to the net, it's either Marcom or Elna caps (1uF 50V 105 degrees electrolytic).
So I went and put in there a 1uF 200V 105 degrees electrolytic.  Now the picture is shrunk to the middle 1/3 of the screen!   :o
These caps are used to drive a AN5521.  If I replace the IC, should that fix my problem? are there any equivalent drop in IC's in case I can't find it local to me?
Better yet, what are "low-esr" caps, and how can I tell them when purchasing?  Do I have to replace the 2 caps with the exact same "red" caps, or are the ones I put in there now good enough?
