Author Topic: Pinball playfield restorations  (Read 1789 times)
mod
  • Last login:June 18, 2008, 06:19:30 pm
« on: August 24, 2005, 06:08:02 pm »
Hello All,
Does anybody know of any sites that focus on pinball playfield restorations?
Thanks for looking.
Regards,
Mod.
lokki
  • Last login:May 05, 2025, 06:18:51 pm
Re: Pinball playfield restorations
« Reply #1 on: August 24, 2005, 06:59:12 pm »
Have you seen marvins?
fix
http://marvin3m.com/fix.htm
and restore
http://marvin3m.com/restore/
« Reply #2 on: August 24, 2005, 08:16:51 pm »
The beginnings of an effort here.
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« Reply #3 on: August 24, 2005, 10:58:45 pm »
I had wanted to refinish the playfield on my Space Mission http://www.ipdb.org/machine.cgi?id=2253 , but I didn't want to risk destroying the paint, plus I don't want to have to strip the underside.
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
fredster
  • It's all good!
« Reply #4 on: August 24, 2005, 11:15:08 pm »
Check out a series of videos called "This old Pinball" one of them had a pretty good demonstration of Marvin3's site.
Marvin3's site is the boss.
USSEnterprise
    • USS Odyssey
« Reply #5 on: August 24, 2005, 11:18:18 pm »
I read through the playfield restoration on Marvin3m, but I would still rather not chance it. The playfield isn't in great condition. There are a lot of dings in the lamination, but the paint is pretty damn good
fredster
  • It's all good!
« Reply #6 on: August 24, 2005, 11:44:50 pm »
Then look for "this old pinball".
They did a restoration in it. These clowns that make it are kinda irratating, but they get the point across.
I don't blame you though. It's a total nightmare to contemplate taking apart a playerfield. There are sooo many little parts and soooo many solder points.
You could just buy one and replace the old one. Kinda pricey, but if you like it, you like it.
USSEnterprise
    • USS Odyssey
« Reply #7 on: August 24, 2005, 11:56:03 pm »
It would be kind of hard to find a NOS playfield for a 30 year old machine
allroy1975
  • Last login:November 11, 2023, 08:51:48 pm
  • I'm a dork!
    • Matt's Mame
« Reply #8 on: August 25, 2005, 12:50:19 am »
oh just vectorize the PF print it out on some vinyl with a good protectant on it, buy a nice 4x8 sheet of hard birch and trace route the old one out.
Should only take a year or ....10.
easy.  ;)
maybe I'll be more help after sleep.
Allroy
They have the FAST Ms. Pac-Man!  MOM!  Can I have a quarter!??
USSEnterprise
    • USS Odyssey
« Reply #9 on: August 25, 2005, 12:58:22 am »
I had been considering a total re-wiring, but then I added up the costs of the asylum visits and decided against it.
« Reply #10 on: August 25, 2005, 08:17:52 am »
The problem with the TOP videos is what they send you.  I've ordered directly from them three times and all three times the DVD was bad.  I just gave up the third time.
Stingray
« Reply #11 on: August 25, 2005, 08:57:13 am »
I can't even imagine what kind of job it would be to totally dissassemble a playfield and then manage to put it all back together again. Best of luck to you.
-S
« Reply #12 on: August 25, 2005, 08:58:50 am »
Depends on the machine, really.  I would cut my freakin arm off before I tried Twilight Zone, but if you had a smallish early solid state, or an EM, there is a LOT less on the playfield.
USSEnterprise
    • USS Odyssey
« Reply #13 on: August 25, 2005, 10:36:33 am »
The Space Mission is a late model EM, and I would be afraid to strip the playfield. There are at least 14 relays on the underside alone. The closest I ever came to stripping the playfield was taking the rubbers, plastics, and bulbs out.
« Reply #14 on: August 25, 2005, 12:19:27 pm »
Why would you have to strip the underside?  Use a playfield rotissery.
fredster
  • It's all good!
« Reply #15 on: August 25, 2005, 01:26:17 pm »
They can be found.  You have to look through the pinball sellers.  You'd be surprised what you can find, especially if the game was poplular.
Look around, check these places:
http://www.k-k-amusement.com/
http://www.marcospecialties.com/MODERN/
http://www.pbresource.com/
http://www.centsibleamusements.com/
You can even have people do it for you.  It's kinda pricey, but ask these people, they know.
« Reply #16 on: August 25, 2005, 01:29:32 pm »
Pricey is an understatement.  The NOS playfields can be found, but often it will take a year or more and cost you four figures.
Some people don't have $1200.  Some machines aren't worth that much.  Say you want to restore an early 80s SS pin that's only worth $450 in excellent shape?  Is that really worth spending a year and 3x the value of the machine to put in a NOS playfield?
mod
« Reply #17 on: August 28, 2005, 07:11:56 pm »
Thanks all for your replies.
I have a 1984 Williams High Speed Pinball that needs some restoration work on the playfield. I am considering doing the work however if I manage to find a replacement playfield at a realistic price, I would consider replacing then tackling the major work needed to restore it.
Regards,
Mod.
USSEnterprise
    • USS Odyssey
« Reply #18 on: August 28, 2005, 09:34:26 pm »
Yeah. Space Mission/Space Odyssey were popular machines, with a combined total of about 16,000 units. I could probably find one.
