Author Topic: Patching an already-painted metal panel?  (Read 2869 times)
TurboC--
  • Last login:December 21, 2023, 12:23:05 am
  • No one can defeat the quad laser!
« on: August 24, 2005, 01:31:02 pm »
I'm trying to fill in some button-sized holes in my metal CP, to shore it up prior to applying my peel&stick CPO.
PetitMorte
  • Last login:December 11, 2015, 10:03:43 am
Re: Patching an already-painted metal panel?
« Reply #1 on: August 24, 2005, 01:40:11 pm »
Well, the standard suggestion is going to be bondo.  I filled in several holes in my metal panel with that.  Just put something behind the hole, gloop the bondo on, and then when it's hard, sand it down smooth.
Bitten by the cabinet bug... obsessing ever since.
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
« Reply #2 on: August 24, 2005, 03:00:13 pm »
I would go with the bondo suggestion.  I would definitely not use wood putty.  One problem with wood putty is that some types of it will shrink after use.. so if you fill a hole with it, the hole may not be filled when it dries!  Bondo is more of a what-you-see-is-what-you-get kind of experience.  Bondo will also be stronger than the wood putty.
-88mph
PetitMorte
« Reply #3 on: August 24, 2005, 03:06:57 pm »
bondo is also designed to be used on metal.
as opposed to wood putty... which is not.
Of course, you could always go with METAL PUTTY!!!
That stuff says you can even powder coat it!!!
HERE is a walk-thru on repairing metal control panels with bondo.
« Last Edit: August 24, 2005, 03:13:14 pm by PetitMorte »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: August 24, 2005, 03:35:58 pm »
Excellent link ... thanks! (I'm not the OP, but definitely goes in the useful links file).
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
TurboC--
« Reply #5 on: August 24, 2005, 03:49:42 pm »
Well, I kinda don't feel like spending the money on bondo (it isn't cheap) just for this one thing.  And even if I did, looking at that patching guide, the guy uses metal plugs on the bottom of the panel.  I don't get this.  Now the panel will not be flush with the wood underneath it.  Maybe he doesn't HAVE wood underneath his?  That's what I was wondering, if bondo was strong enough to form a patch without anything (like metal plugs) holding it underneath.  According to this guide - apparently not.  So I am back to my original options, and it's looking like duct tape may win out! (At least it's thin...)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #6 on: August 24, 2005, 03:58:35 pm »
......the guy uses metal plugs on the bottom of the panel.  I don't get this.  Now the panel will not be flush with the wood underneath it.  Maybe he doesn't HAVE wood underneath his?
There is a complete plank of wood underneath the metal control panel?
If that was the case, then your joys and buttons mount through both a metal panel *and* the wood underneath?
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #7 on: August 24, 2005, 05:04:41 pm »
How about good old JB weld!  That stuff is pretty strong and they say you can file it, sand it and drill it!
http://jbweld.net/index.php
Here's just some of the  stuff it will work on!
I think it only cost a few bucks for the stuff at any auto store!
fuel tanks
radiators
cracked engine blocks
transmission & rear-end casings
cylinder heads & sleeves
generators, starters, water & fuel pumps
axles & hubs
valve guides
press fit bearings
crankshaft pulleys
casting defects
door stops
key ways
stripped threads
body shop repairs
« Last Edit: August 24, 2005, 05:20:59 pm by creatine28 »
PetitMorte
« Reply #8 on: August 24, 2005, 05:44:05 pm »
The reason that he has the metal plug underneath is to keep the "wet" bondo from just falling through.  Bondo when mixed up and applied has the consistancy of toothpaste.
When I did my metal panel, I used a fine metal mesh behind the panel to hold the bondo in place.  Once it hardened, I could sand down the back until iit was flush as well as the front.
The small bondo kits are only about $10 at Auto-Zone.
TurboC--
« Reply #9 on: August 24, 2005, 05:49:14 pm »
Mesh eh.  Seems unnecessarily messy when you could use something non-porous.  I don't want to use duct tape, but I was thinking about what other materials would be thin enough to not cause a problem in mounting, but inflexible/hard enough at that thickness to do the job.  Maybe they sell metal that's thin but not too thin.  Hmm...
Pik4chu
  • Last login:April 09, 2012, 01:35:17 pm
  • So what was I supposed to put here?
TurboC--
« Reply #11 on: August 24, 2005, 08:01:49 pm »
But what is supporting the patch job?  That's the general problem.
CheffoJeffo
« Reply #12 on: August 24, 2005, 08:17:43 pm »
I echo SteveJ34's question (I am having real trouble visualizing how the plugs can cause a problem when you have buttons, joysticks and other things that stick much further out) -- if putting the plugs underneath is a problem, then perhaps a picture of the metal/wood CP would help us make recommendations.
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
Pik4chu
« Reply #13 on: August 24, 2005, 08:52:13 pm »
TurboC--
« Reply #14 on: August 24, 2005, 09:32:17 pm »
Directly flush beneath the metal CP is the solid wooden section of the CP.
CheffoJeffo
« Reply #15 on: August 24, 2005, 09:39:02 pm »
Still don't really get it -- the only panel that I have that contains both metal and wood is on my big Capcom cabinet adn they are glued together instead of in two pieces.
I guess I would ask if the holes go through the wood as well (I presume that there are matching holes in the metal and wood to accomodate buttons and joysticks).
Cheers.
Working: Not Enough
Projects: Too Many
Progress: None
TurboC--
« Reply #16 on: August 24, 2005, 10:41:31 pm »
No, the holes do not go through the wood in most areas.  Just the metal.  The whole panel was hacked up to convert Pac-man to a trivia game.  I restored the wood part very nicely.  Now I have to patch the holes in the metal.
Pik4chu
« Reply #17 on: August 24, 2005, 11:57:58 pm »
TurboC--
« Reply #18 on: August 25, 2005, 02:12:02 am »
in that case the support for the bondo should be provided by the wood panel backing, no?
Not unless it's 100% perfectly flush at all points?  (It isn't.)  And not unless it is currently installed?  What happens when I have to remove my metal panel?  Sounds like a really bad idea all the way around.  And aluminum foil looks only marginally better than duct tape.  Why spend another $10 on bondo just to have aluminum foil all over my panel.  I'd rather just duct tape in some stupid cutouts of plastic, or whatever better "cheap as free" method I can think of with stuff I have lying around.
Pik4chu
« Reply #19 on: August 25, 2005, 03:02:52 am »
Not to nit pick but you never said anything about removing it, just that you needed the surface to be flat for your CPO :)
« Last Edit: August 25, 2005, 03:09:16 am by Pik4chu »
TurboC--
« Reply #20 on: August 25, 2005, 03:55:01 am »
I guess, not sure that would be thin enough though.
« Last Edit: August 25, 2005, 03:57:01 am by TurboC-- »
TurboC--
« Reply #21 on: August 25, 2005, 04:32:47 pm »
Goof Off can wins again!  In addition to cleaning the artwork, and the can's paint providing a near-exact color match for Pac-man yellow, now the rest of the pieces of can made a nice metal patch for the control panel.   ;D  I feel like a Native American, using every part...
