Author Topic: will this arcade monitor plug into a pc please help  (Read 1638 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: August 21, 2005, 08:08:03 pm »
Hi I'm looking at this monitor. Its a vision pro 19" SVGA Horizontal Mount Monitor from happs.  I belivve its a plug n play type but im not sure.
http://happcontrols.com/monitors/491337vp.htm
My question is
« Last Edit: August 21, 2005, 08:17:04 pm by rlemmon »
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
Re: will this arcade monitor plug into a pc please help
« Reply #1 on: August 21, 2005, 08:25:59 pm »
Yes, this will work on a regular PC.  It is a 30-38KHz monitor, so it will only do VGA and SVGA (640x480 and 800x600).  It uses a standard 15-pin D-Sub connector (ie: the "VGA" connector that comes out of your PC's video card).
You cannot use this monitor to do low-frequency modes, such as the 15KHz and 24KHz modes than an ArcadeVGA can output.
rlemmon
« Reply #2 on: August 21, 2005, 08:31:35 pm »
thanks Elvis, Is it a big deal that it won't support low-frequency modes. Would it affect the appearance of Mame games? Do you know if it includes the sub connector cable or do i have to buy it separately ?
thanks again for the help :)
« Last Edit: August 21, 2005, 08:39:47 pm by rlemmon »
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
« Reply #3 on: August 21, 2005, 09:20:58 pm »
It just means that you cannot run arcade pcb's on the monitor - only video sources that output VGA, such as a computer or Naomi =)
« Last Edit: August 21, 2005, 09:22:36 pm by Nipedley »
