Author Topic: Bad Microswitch?  (Read 840 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
Bad Microswitch?
« on: August 20, 2005, 02:40:55 pm »
Ok, I have started wiring my control panel to an ipac 4, and for some reason the down on my 8 way switch wont work. I have a 4 way balltop wired to the same terminal, and the down switch on that one works.... I have rewired it 3 times now and the down switch on the 8 way still wont work, while it does on the 4 way, and all the other buttons do too. I have made sure the switch gets hit, and it does, so the only conclusion i can make is its a bad microswitch, what do you think? Can you replace them on a joystick?
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
pointdablame
  • Last login:Today at 06:16:22 pm
Re: Bad Microswitch?
« Reply #1 on: August 20, 2005, 02:44:33 pm »
Of course you can replace them.
Swap one of the other micros on the joystick to the down position just to check it.  If it's a bad micro, just order a new one
first off your and idiot
the3eyedblindman
« Reply #2 on: August 20, 2005, 05:39:42 pm »
Ok, i switched it and now it works... it was the pushbutton, thanks.
