Author Topic: Help wiring Perfect 360  (Read 1275 times)
Mani
  • Last login:August 19, 2005, 11:20:16 pm
  • total arcade addict
    • my homepage
« on: August 18, 2005, 10:07:06 pm »
Hi all,
Could someone please explain (the way you would explain to a child ... I'm pretty clueless when it comes to wiring and electronics) how to wire the +5v to my 2 perfect 360's?
My setup: Mk2 (jamma) cabinet converted to MAME cab. I'm using a PC and a J-PAC.
I found comments about wiring the +5v from the "led header" of the J-PAC. I'm not sure what this means. If anyone could explain this to me, it would be greatly appreciated!
Thanks, and sorry again for the total cluelessness.   :-\
ScoopKW
  • Last login:August 06, 2006, 08:32:53 pm
  • Stage one complete, pix coming
Re: Help wiring Perfect 360
« Reply #1 on: August 18, 2005, 11:17:29 pm »
The best way is to wire it from the molex connectors on your computer. (The plugs that plug into your hard drives and CD-roms and such.)
The RED wire on that plug is five volts. And the black wire next to it is ground for 5v. Don't use the other two, because they are 12v wires...
ScoopKW
Mani
    • my homepage
« Reply #2 on: August 19, 2005, 11:31:43 am »
Thanks Scoop!
So, I'm guessing I'll do this:
1) cut off the actual plug on the molex connector
2) wire the red to the +5v to the P360 #1
3) from the +5v of P360 #1, run a wire to the +5v of P360 #2
4) repeat steps 2) and 3), but for GND (black wire) instead of the red +5v
Does this sound right?
Cheers,
Mani
Level42
« Reply #3 on: August 19, 2005, 11:51:00 am »
Sounds correct to me. If not, your PC supply simply won't start up. These things are pretty well protected against shortages etc. However DON'T switch the +5V and the +12 V :)
Mani
    • my homepage
« Reply #4 on: August 19, 2005, 12:22:49 pm »
Thanks for the help!!!
Think I can do this without any soldering? Just tie the wires together and wrap it up with electrical tape?
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
« Reply #5 on: August 19, 2005, 12:54:52 pm »
or use a butt connector
thou shalt not supress flatulence
-the bassmaster general
Level42
« Reply #6 on: August 19, 2005, 04:21:21 pm »
Do a decent job ! No, this will not make a good contact !  Your sticks may stop working temporarely or who knows what happen if the 5V is going to be "sparkling" !! Your best bet would be finding a T-splitter for the power connector (like this: http://iec.cc/l1063.html), cutting off the unneeded connector and wires and solder your wires on that. Strip the wires, twist them together, solder them and then use some shrink isolation.
Mani
    • my homepage
« Reply #7 on: August 19, 2005, 11:20:16 pm »
Good call Level42, I will probably do something like that in a couple weeks. Right now I did it using butt connectors. I dont like these things. The wires dont feel secure enough in there.
Other than that, it works great!!! Thanks a lot to everyone in the thread that helped out. I really had no idea how much of an improvement P360's make in fighting games. They are definately worth the $$$ if you're a fighting game fan. No more clickity-click!!
Cheers,
Mani
Level42
« Reply #8 on: August 20, 2005, 05:23:06 am »
