Author Topic: from what i heard from this board...  (Read 2482 times)
bossyman15
  • Last login:March 05, 2012, 01:35:08 pm
  • I am now building my own arcade controls!
    • Bossyman15 Arcade Pics
« on: August 18, 2005, 01:07:07 am »
you can burn Dreamcast ISO on cd rw and pop it into DC? just like that?
My website: www.bossyman15.com Lots of arcade pictures inside!
Goz
  • KOTA
Re: from what i heard from this board...
« Reply #1 on: August 18, 2005, 01:16:21 am »
For the majority of ISO's circulating yes... some imports and older ISO's will often require a boot disk (Utopia).
-Goz
bossyman15
« Reply #2 on: August 18, 2005, 01:18:08 am »
oh my DC is US version. i can put europe and japan iso in there?
Goz
  • KOTA
« Reply #3 on: August 18, 2005, 01:21:04 am »
Depending on how the ISO was created. You may or may not need the Utopia boot disk.
Stingray
« Reply #4 on: August 18, 2005, 10:43:05 am »
If you look on the bottom of a DC there's a number in a circle. This number will tell you which DC you have. The number is either a '1' or a '2'.  Sadly I can't remember which is which. Probably a google search will turn that info up for you. If I think about it, I'll look on the bottom of mine and let you know, mine is the one that will boot CDRs without a boot disk. I'm pretty sure the one with a '1' on the bottom is the one you want.
-S
forbiddenlyrics
  • Last login:July 10, 2010, 03:19:34 pm
  • I'm Bart Simpson Who The Hell Are You?
« Reply #5 on: August 19, 2005, 04:02:05 am »
You will need to burn CD-R's to use in a DC. To use CD-RW's you will have to adjust your laser.
